I project to build a Vibroclone which includes major mods to achieve kind of Vibroverb tone on steroids
I plan to use a silverface bandmaster and convert it , using chassis and also the wood from his large cabinet to build an accurate Vibro cabinet period correct.
Here is the heart of project : I would like to achieve with my clone the same sound as we can get with an amp coupled to a Kingtone Blues Power pedal which is made to replicate a blackface pushed hard on tubes , however the tone with this pedal is way more than that and sounds beyond belief , it is a Vibroverb tone but bigger , fatter, juicy , low mids and still with ton of chime and glass. It's like the whole Stevie's stack of amps in just one amp !!
The thing is I don't want to use a pedal because it's just full of print and chips , I am sure it's possible to tweak and elaborate the AB763 circuit to get that fabulous tone naturally or closer .
Here is a link of the tone I am refering and despite the title , it's all from a Blues power pedal
https://www.youtube.com/watch?v=OMxzXkz-5A8
And here the link of the Blues power schematic and components list
https://aionfx.com/app/files/docs/duran ... tation.pdf
I played trough an amp with a B/P pedal and it's absolutely stunning !
The SRV sonic possibilities with that pedal are incredible , you have that specific 1983 ACL concert tone or famous Mocambo tone or even that 1985 soul to soul session tone in a fingers snap , it's just the combination of toggle switches and EQ.
My question is how to get the same result from a tweaked blackface circuit ? What components and values to change ?
Before continue I have to mention I owned in the past a real Vibroverb/Altec 15" modded with some SRV tips and it sounded glorious and more consistent , however when pushed hard , the tone became high mids /muddy and kind of collapse in some way . This is where the B/P pedal is fantastic , you can counteract that to keep a huge GLASSY and bassy tone at high volume, his EQ allow to beef up all frequencies.
I think the leads are basically usual SRV mods (already well documented) and here the main issue, a more elaborate EQ design than the usual blackface Bass/mid/treble option value.
The pedal clearly expore enlarged range of frequencies so the idea is to "open" the range of the original Fender EQ. More bass , lowered mids BUT still keeping the clear and glassy tone.
Here are my questions and what with common sense I think are the direction to follow, but ANY suggestion are welcome
How to implement in the circuit a controle pot to increase the "Glassy" effect in tone ? (Glassy is reffering to a boost of treble in specific range of frequencies)
How to enlarge the Low mids frequencies band ?
The pedal use toggle switces ( 4) to voice it differently , is it pertinent to implement this in the amp circuit ?
I am not qualified enough to redesign an AB763 circuits and I would be grateful to have the help of skilled technician in the forum , it would be so helpful for all of us sought after this tone.
Any constructive suggestion or comment are welcome
Thank you very much
