It doesn't match any of the versions popping up on Google or sent to me by Fender. One of the obvious differences is spots for grid stopper resistors for the preamp tubes on the PCB designated as R66/67/68/69/70/71 (I found a schematic that shows 10k resistors in the same spots, but with different designations amongst other differences). So many components have been snipped and resoldered from the top that it's impossible to tell what exactly the original build was. There are plenty of ways I could wire things up that would work of course, but I'd like to put this guys amp back together as it was originally built (he said he bought it because he liked the sound of these, without realising the previous owner had absolutely stuffed it).
Failing a schematic, the mystery components aside from the ones above are R11/35/41/42/C20 so if anyone has the same model and can check values that'd be amazing. From memory all of those show up as omitted on one or more versions of the schematic, but again- none of those actually match this amp.
Thanks!
