BLACKFACE BOARD TEMPLATES
I've been searching for Princeton Reverb (and other blackface) board templates on the web and have come up quite empty. I was able to find a Hoffman layout template on this site but I'd like to use the more stock version. Is there a good source for AA1164/AB763 board templates that you know of? Thanks.
Just plug it in, man.
Re: BLACKFACE BOARD TEMPLATES
Hoffman makes all of the old Fender boards using the original layout on a 1/8" fiberglass board. See this page for more info...
https://hoffmanamps.com/MyStore/perlsho ... =!ORDERID!
Here's his PR AA1164 board...
Go to Mojotone if you want the cheap fiberboards as found in original Fender amps.
I have used the mojotone tone ones many times and there fine for a Princeton build, if I would building something running 450 volts I would look elsewhere!
- dorrisant
I can make what you need. G10/FR4 in black or light green (the colors I have at the moment) or the gray circuit card material from AES/CED.
PM me if interested.
