Calling Martin Bombay!
- Reeltarded
Hey, Martin.. if I were going to make this vibrato more insane than it already is.. what would you do? lol
- Reeltarded
Re: Calling Martin Bombay!
As an aside, Normal channel is medium rage distortion unit cascaded onto the Vib channel. Vib channel is 124'd. Vib channel EQ is basically stock but I clipped that stupid 70k tap off the treble (because tone doesn't have time for that.. if Leo patented that, he was a dimwit)
Have a look at the revibe and see if there are any interesting harmonic vibrato mods. Maybe sluckey’s version has some tweaks?
- Reeltarded
K, will do! It's almost deep enough to make me happy the crossover point probably needs something..
- Colossal
That thing sounds great. Like a Dumble in an aquarium.
- Reeltarded
Thanks, Martin. I am already over there and messing with the monster a lil.
Thanks, Dave. Yiu were absolutely right about direction. I am surprised how much the cathode changes brought the output down.
Thanks for the revibe thing, Sluckey!
Bombacaototal
That is great Martin! Thanks for sharing.martin manning wrote: ↑Mon Nov 05, 2018 12:49 am Here ya go: http://sluckeyamps.com/revibe/revibe.htm
I always wanted to try this circuit, might be an idea for a future amp. On a build where this circuit would be "build in" would you place the tremolo in front of everything else (as if it was a stand alone unit in front of the amp) or between the tonestack and the PI as per Fender brownface amps?
- Reeltarded
This unit is made to plug into the amp input.
If you are going to build a vibrato circuit into an amp, you should look at the Bandmaster schematic above. It takes three tubes to do it, but it is basically a tube Univibe. It doesn't do swamp; it does Jimi and Robin Trower.
Bombacaototal
Thanks! I played a '63 brownface concert once and absolutely loved the harmonic vibrato. I am curious to the mods you will settle on.Reeltarded wrote: ↑Mon Nov 05, 2018 12:08 pm This unit is made to plug into the amp input.
I also wonder how different the unit at the input sounds to the Bandmaster schematic above.
- Reeltarded
I replaced the 4u over the 4k7 with a Mal electrolytic 5u. I have a 4u film cap. 20% +/-10% is larger than it needs to be.
Question: In that mixing scheme I am looking for values that give maximum warble given a strong and balanced tube. I think the crossover points could come down a lil and contribute to more seasick. I can't draw on this device. Bummer.
If I make both the caps bigger, that will increase the slope of each side, will it not It's just an inverted pair of flters. Solve for both and pick a pair..
- Reeltarded
Bombacaototal wrote: ↑Mon Nov 05, 2018 12:12 pmThanks! I played a '63 brownface concert once and absolutely loved the harmonic vibrato. I am curious to the mods you will settle on.Reeltarded wrote: ↑Mon Nov 05, 2018 12:08 pm This unit is made to plug into the amp input.
Here is my Twin Amp mostly clean
https://www.dropbox.com/s/vfwtb8b2bdyn8 ... 4.MOV?dl=0
brb
Bandmaster before this round of changes mostly not clean
https://www.dropbox.com/s/9vmrd6f0x9rg8 ... r.mov?dl=0
- pompeiisneaks
- Site Admin
I know he's not going to toot his own horn, but if you guys haven't checked out all of sluckey's stuff on his site, you're missing tons of great info www.sluckeyamps.com
You'll dig it!
~Phil
You'll dig it!
~Phil
tUber Nerd!
- Reeltarded
Yes, he mKes things make sense that make sense!
I fall untall of that... shucks.
Nice !pompeiisneaks wrote: ↑Mon Nov 05, 2018 5:29 pm I know he's not going to toot his own horn, but if you guys haven't checked out all of sluckey's stuff on his site, you're missing tons of great info www.sluckeyamps.com
You'll dig it!
~Phil
Thx,
