Debating a brownface super build
beasleybodyshop
After seeing the whole thread on "what amp is this" earlier its spurred my interest in build a 6G4A super with the three tube tremolo. After looking at the schematic, however im seeing a few nonstandard parts in this bad boy:
Tone stack is kind of odd - treble is a 350K pot with a 70K tap. looked around and couldnt find one
Speed pot is a 4 Meg Reverse Audio taper....ditto on finding one. I do find 3 meg reverse tapers quite a bit though, could that be used as a substitute? Maybe have a 1 meg resistor tied to it - make it switchable so you could at least get down into the range that a 4 meg would offer?
Schem for the 6G4-A doesnt list the value of the intensity pot either.
Other than the wacky pots, it looks like its a doable build. Thoughts on building one to me are removing the normal channel, possibly swapping in a blackface tone stack (if i cant find a workaround for the treble pot) and using a fixed value for the midrange, and a true adjustable bias instead of the fixed resistor. maybe use that extra tube for an effects loop or built in d'lator. This thing is going to be in head format, and with no reverb having a loop would be nice.
- JazzGuitarGimp
Re: Debating a brownface super build
The 350K / 70K pot is available at weber, though I've read here that the taper isn't quite right. The intensity pot is 10M-RA and I don't know where that can be found. As for the speed pot, it might be possible to use a 3M-RA and scale the fixed resistors in the circuit down 25% and the capacitors in the circuit up 25% to get the same speed range.
eniam rognab
these are my same questions!!
you read my mind
or we talked yesterday, i cant remember, i have clinical CRS (cant remember shit)
thanks for posting these questions, im sure you will finish the build before me, and troubleshoot, so thanks again in advance!!
beasleybodyshop
Thanks! i forget to check weber. Saw that this amp build has been documented before, but no one mentioned dealing with the 10 meg or the 4 meg pot or how to get around that on TGPJazzGuitarGimp wrote:The 350K / 70K pot is available at weber, though I've read here that the taper isn't quite right. The intensity pot is 10M-RA and I don't know where that can be found. As for the speed pot, it might be possible to use a 3M-RA and scale the fixed resistors in the circuit down 25% and the capacitors in the circuit up 25% to get the same speed range.
Gonna keep looking.
- Reeltarded
Eee. Bay.
Do not buy all the spares.
Doug Hoffman carries the tapped pot.
http://hoffmanamps.com/MyStore/perlshop ... =300111572
beasleybodyshop
we can save you someReeltarded wrote:Eee. Bay.
- Reeltarded
Seriously let's get all the stuff together to do some and I will convert this dual showman thing and this other bandmaster.
It's a groovy sound but I don't like playing that amp, I mean I am scared to mess with it much. There. Scared mostly.
vibratoking
I was gonna build one too until Miles graciously offered to send me his...he's not using it.
beasleybodyshop
In my infinite obsession i managed to pull together a BOM for a single channel iteration with a selectable output impedance. stuff is from mouser and Antique electronic supply....oh yeah and iron is classictone.
i threw in some dumble inspired stuff, MF resistors where they would usually go and what not. use your discretion.
good luck. someday I will start this build.
Edit: I forgot to add tube sockets. lol.
- Reeltarded
I'm scared to ship it.
Hoffman has both 10mRA and the 350k tapped pots.
http://hoffmanamps.com/MyStore/perlshop ... =531138366
I had to get mine from Germany last year the only place I could find that 10mRA pot at that time.
beasleybodyshop
Thanks Mark!
Can't go wrong w/ a brown Super:
https://www.youtube.com/watch?v=lxhvb69b264
Al Anderson (paisley tele) should be using a brown Super, was whenever I saw them around that time.
Speakers are critical. No suggestions, I'm sick of speakers.
- Reeltarded
