5F4 (Tweed Super) help
Fender Amp Discussion
sixstringer
Post by sixstringer »
I inherited a finished (but buggy) 5F4, I've been going through it, correcting minor issues here and there. It works but is a little noisy, I've just discovered that the tone controls both work as volume controls, that is, they do not effect the treble or bass as you would expect but rather, they will roll off the signal to nothing. Any clues about how to track down the problem?
Thanks in advance
ToneMerc
Re: 5F4 (Tweed Super) help
Post by ToneMerc »
sixstringer wrote:Any clues about how to track down the problem?
Thanks in advance
For starters, verify your as built against a known layout.
TM
Post by Stevem »
Are the treble and bass pots you used indeed 1meg which they should be and not 100K?
Is the wire coming off the trebles wiper feeding the out bound side of the 220k resistor off the bass pot?
sixstringer
Confirmed 1 meg pots for both. a 220k resistor connects the center lug of the treble pot to the center lug of the bass pot. The center lug of the treble pot connects to a pin 2 of V3 (the (PI), the center lug of the bass pot connects to a 100k resistor per the 5F4 layout and schematic.
To clarify, the volume pot(s) still control of overall output, each tone control will attenuate that volume is to zero with turn all the way down. There is no effect on the tone with the tone controls.
Post by Stevem »
The 5f4 schematic I just looked at shows the wiper of the treble pot feeding the input / grid of the next gain stage which is also the out bound side of the 220k resistor that comes off the right hand lug for the bass pot, which is not as you posted!
Zippy
Post by Zippy »
sixstringer
Mine is wired as shown in the layout.
Post by Stevem »
And the layout is wrong!!
Zippy
Post by Zippy »
Hah, I didn't notice that. I just googled the layout, and this one popped up at the top of the list. If the layout is wrong, that might explain the problem.
sixstringer
The amp is wired per the layout shown in the previous post. This is incorrect?
sixstringer
I reviewed other layouts for the 5F4 and they all indicate the same connections for the tone controls (including the Fender layouts and the version on the Weber site).
Firestorm
Post by Firestorm »
That layout looks like it matches the schematic and the 5E5 as well, unless I am not seeing something.
vibratoking
Post by vibratoking »
Firestorm wrote:That layout looks like it matches the schematic and the 5E5 as well, unless I am not seeing something.
+1
sluckey
Post by sluckey »
Stevem wrote:The 5f4 schematic I just looked at
Can you post that schematic?
sixstringer
I resolved another is issue, the presence pot was wired incorrectly but correcting it did nothing to decrease the hum or resolve the tone circuit problems. Chop sticking my way around the chassis I did notice that the pin 2 lug of V2 is very microphonic and that changing the tube did nothing to make it less so.
