Fender PA 100 conversion to Trainwreck
Fender Amp Discussion
Bieling3
Post by Bieling3 »
First post from a less than novice wanna be amp builder, putting on my flame suit... :oops:
I'm thinking of buying back my old Fender PA 100 from the guy I sold it to a couple of years ago. At first I was thinking of just tinkering with the preamp but now I'm considering gutting it, keeping the transformers and reverb and starting anew.
Considering the specs; Power Transformer putting out 640V CT @ 450ma with a 60V bias, 6.6v @5.5A and a 2k 100 watt output transformer at 4ohms would this be a good candidate for an 80 watt Trainwreck Express build like in this thread:
https://tubeamparchive.com/viewtopic.php?t=7759
Are there any other builds I should consider beyond just doing the Blackface Twin Reverb route? What do you guys think about the Triode USA kit?
http://www.triodeelectronics.com/twtubeampkit.html
Tone is in the instruments. Technique in the hands. Do what you will.
Bieling3
Re: Fender PA 100 conversion to Trainwreck
Post by Bieling3 »
Reading through some of the posts here it looks like the transformers won't be able to handle el34s and/or the impedance will be off if I go with just a pair. Is this right? If I stay with 6l6s will that be compatiblel with the Trainwreck Express tone stack?
Did I post this in the right forum?
mhartman
Post by mhartman »
Don't bother with the PA100, it is too big and bulky and Fender transformers aren't right for an Express. Instead, spend the money on a set of transformers and a fresh trainwreck sized chassis.
I bought a PA135 a while back with high hopes, but I found that the only rel value is the transformers and the old pots. In the end, I didn't want an amp that huge.
Post by Stevem »
my first question for you before anything on the technical side is this.
Have you ever played thru a even a 50 watt amp flat out and gauged its volume level and do you need a amp that will be pretty much that same (the 100 watter) but with twice the amount of clean head room before the output stage clips?
ToneMerc
Post by ToneMerc »
mhartman wrote:Don't bother with the PA100, it is too big and bulky and Fender transformers aren't right for an Express. Instead, spend the money on a set of transformers and a fresh trainwreck sized chassis.
+1 sage advice
TM
echuta13
Post by echuta13 »
Much better for a Dumble build, but not a TW. I think Fuchs uses them as a foundation for one of their conversions.
If you can't be a good example, then you'll just have to be a horrible warning.
Bieling3
Post by Bieling3 »
Truth be told my favorite tones I ever got from an amp was a JCM 800 4104 dimed on the low input. Maybe I'll pass on the PA 100 and go back to looking at that JTM 50 kit.
Bieling3
Post by Bieling3 »
Overtone or SSS?
mhartman
Post by mhartman »
Bieling3 wrote:Overtone or SSS?
You could do a nice 100w. SSS with it. 6 preamp tubes plus room for one more sets it up nicely. Still, unless it is really cheap, do a fresh build instead of a conversion.
dreric
Post by dreric »
Bieling3
Welcome to the forum.
Trainwrecks, Dumbles and Fenders are completely different beasts.
They are their own amps but Trainwreck come from a Marshall/Vox family tree while Dumbles have their origins in the world of Fender.
This thread would help you get to know the Dumble world:
https://tubeamparchive.com/viewtopic.php?t=11906
There's lots of links to sounds on the Wreck side also.
Personally I think a kit of a straight build would be better for a first time than trying to mod
Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
