5e3 power tranformer (?)
Hi,
does anybody have something to suggest me about a new 5e3 PT?
I prefer something in EU, in order not to have such high shipping costs
i had a Weber one, but it's blown now... my 5e3 is Weber's kit, too
i can't afford expensive PTs, so i'm looking for just a better than the Weber one
Thank you!
Thank you!
Re: 5e3 power tranformer (?)
Hammond 290AEX should be available in EU.
http://www.hammondmfg.com/guitarLinePWR.htm
yeah,it's available, thank you martin!!
AEX is a Champ-sized PT, plus only 81mA on the HT.martin manning wrote:Hammond 290AEX should be available in EU.
The 290BEX or 291BEX might work. Available from Tube-Town in Germany. TAD offers something as well, but I don't see any spec's.
According to Hammond AEX is a PT for tweed deluxe, not BEX. Do you think I should put on a bigger one?
I read Tweed Deluxe on Hammond's site too, and that one is probably for the 5A3 "TV front" Deluxe.
Measure the mounting centers on the PT you have. Hammond lists 290BEX as being for Deluxe and Deluxe Reverb, with 2-1/4 x 2-13/16 (57.2 x 71.4mm). Magnetic components lists their 40-18021 for 5E3, with those same mounting centers, so 290BEX is likely correct.
Last edited by martin manning on Sat Jan 25, 2014 7:12 pm, edited 2 times in total.
so, let's say both fit.which one would you choose?do i have to look for something specific in their specs?as both fit.
thank you very much
thank you very much
The 290AEX has 2" x 2-1/2"mounting centers, so you need to check. I'm thinking you need a 290BEX.
https://taweber.powweb.com/store/025130eusch.jpg
http://www.hammondmfg.com/pdf/EDB291AEX.pdf
http://www.hammondmfg.com/pdf/EDB291BEX.pdf
My PT is the first one, an i see the voltages are different in all 3 PTs. As i'm not a specialist, i don't know if i can replace the first with the other, can i? Any consequences with this replace?
The bolt centers are matched by the 291BEX. Is your line voltage 220 or 240V?
the line voltage here is meant to be 230v +-5...
when i was building my 5e3, i asked a technician and he told me to connect the 240v line of the PT. Was he right? Every other device i have in my house is 100-240v...
Ok sounds good. Here is how you would connect the Hammond PT.
thank you martin!!
