Issue With Bassman 5F6A Build
Fender Amp Discussion
Guitarnut
Re: Issue With Bassman 5F6A Build
Post by Guitarnut »
martin manning wrote:Pin 2 should read zero volts. Definitely a problem there. Look for a solder bridge or strand of wire shorting those two pins.
It was a small solder bridge. I cleaned up the joint on pin 2 and pin 1 is showing same voltage as pin 6 now.
I plugged in all the tubes and did one more check. I have a warm glow on everything but 2 two 12ax7s. They're dark. Proper voltages on 1 & 6, heater voltages are good.
I'm getting discouraged boys. I gotta call it a night.
Thanks again for all the help, I'll take another go at it tomorrow evening.
Peace,
Guitarnut
Post by Guitarnut »
Reeltarded wrote:Close up picture of what is going on in that part of the amp would be good about now! It's simple. You are really close.
I know but my camera sucks in macro. I haven't figured out how to get sharp images without using the flash which blows out the exposure. I'll try it on a tripod without the flash tomorrow.
Peace,
The filament glow can be hard to see on some tubes. If you have filament voltage at all of the sockets it may be that there isn't any problem. Put all of the tubes in and get voltage measurements at all of the tube pins so we can see where you are now. Any noise from the speakers? Lots of progress over the last two days...
Guitarnut
Post by Guitarnut »
Okay, here we go...obviously some issues to work out on V1 and V2. Looks like my PT is lagging as well.
Line=121VAC
F1=468v
F2=465v
F3=430v
Bias after diode -64v
Bias at15K/second filter cap -57.5v
Top of 10K 2W 429vdc
Bottom of 10K, +of 8uf cap, junction of 100Ks 350vdc
Standby switch from pin 8 V6 476vdc
V1
1 107vdc
2
3 33vdc
4 3.36vac
5 3.36vac
6 156vdc
7
8 3.3vdc
9 3.36vac
V2
1 202vdc
2
3 12.8vdc
4 3.36vac
5 3.36vac
6 350vdc
7 196vdc
8 196vdc
9 3.36vac
V3
1 425vdc
2
3 loud noise thru speakers - couldn't meter
4 3.36vac
5 3.36vac
6 425vdc
7 50vdc
8 loud noise thru speakers - couldn't meter
9 3.36vac
V4
1
2 3.36vac
3 468vdc
4 468vdc
5 -57vdc
6 466vdc
7 3.36vac
8
V5
1
2 3.36vac
3 468vdc
4 468vdc
5 -57vdc
6 466vdc
7 3.36vac
8
Rectifier
1
2 467dvc (5.3vac)
3
4 351vac
5
6 351vac
7
8 467vdc (5.3vac)
Still got the bulb limiter in? If so take it out, then measure voltages.
Guitarnut
Post by Guitarnut »
Checking against other builds, looks like V3 pins 3 and 8 are way high...probably causing the issues on V2 and V1?
http://www.tdpri.com/forum/shock-brothe ... ost4955460
Peace,
Guitarnut
Post by Guitarnut »
martin manning wrote:Still got the bulb limiter in? If so take it out, then measure voltages.
Arghhh! It will have to wait until this evening. I have to get to the office.
Peace,
It does look like something is wrong with pins 3 and 8 on V3, so there is value here. Its probably a good idea to track that down before upping the voltage. Look for a short to B+, or possibly a wiring error. They should be around 40V when you are at full line voltage, maybe 30-ish with the limiter.
Guitarnut
Post by Guitarnut »
martin manning wrote:It does look like something is wrong with pins 3 and 8 on V3, so there is value here. Its probably a good idea to track that down before upping the voltage. Look for a short to B+, or possibly a wiring error. They should be around 40V when you are at full line voltage, maybe 30-ish with the limiter.
Updated my numbers in previous post. I didn't see this post until I checked without the limiter...work can wait.
Definitely a problem on 3 and 8 V3. I'm unsure of 7 and 8 on V2 as well. Will investigate.
All other voltages came up nicely. I can actually smell the tubes burning in now. The PT voltages are back up to spec as well.
Thanks again for your continued help.
Peace,
Guitarnut
Post by Guitarnut »
Also, I'm hearing just the slightest sound of bacon frying thru the speakers. I have to get very close to hear it.
Peace,
Where you have no voltage listed above does that mean that you read zero volts at that pin? If so V2 looks ok to me, but V1 and V3 do not.
Guitarnut
Post by Guitarnut »
martin manning wrote:Where you have no voltage listed above does that mean that you read zero volts at that pin? If so V2 looks ok to me, but V1 and V3 do not.
Yes.
Guitarnut
Post by Guitarnut »
I've looked but can't find a list of the voltages I should be seeing and where. I know they'll vary depending on tubes and trans but is there a list that you know of that shows ballpark pin voltages for this circuit?
Peace,
Guitarnut
Post by Guitarnut »
deleted
Yes go to Fender support and get the '59 reissue Bassman schematic. http://support.fender.com/schematics/gu ... ematic.pdf
