5x3 6L6 deluxe
Fender Amp Discussion
Baxtercat
Re: 5x3 6L6 deluxe
Post by Baxtercat »
billyz wrote:If you are going to use 270 Ohm instead of 250 Ohm Bias cap then your Power tubes will run a shade cooler anyway.
Z
'resistor' you mean...[we knew that] :)
btw, what approx. size R would you recommend for 4 6L6s in a case like this?
Guitar Bob
JazzGuitarGimp
Re: 5x3 6L6 deluxe
Post by JazzGuitarGimp »
Z
Actually, I prefer the 250 ohm cap... :D
billyz
Re: 5x3 6L6 deluxe
Post by billyz »
Yeah, I need a proof reader. 250 ohm bias resistor. For 4 6l6's , 125 ohm 30watt.
billyz
Re: 5x3 6L6 deluxe
Post by billyz »
I just modded a Showman( was a basket case) used individual 500 ohm 10w bias resistors and individual 25uf caps across each one. Sounds Great. Tubes are running cool .
billyz
Re: 5x3 6L6 deluxe
Post by billyz »
billyz wrote:Yeah, I need a proof reader. 250 ohm bias resistor. For 4 6l6's , 125 ohm 30watt.
There , I fixed it just in case someone tries to install a 250 ohm cap. :)
JazzGuitarGimp
Re: 5x3 6L6 deluxe
Oh no!!!!!!!! Baxtercat and I will have to remove our posts now! :lol:
ampmike
Re: 5x3 6L6 deluxe
Post by ampmike »
Ok,I'm working on this amp and I'll be asking some guest ions,the pilot light should or should not have 2 resisters to ground. Are they 100 k?Mikey
Re: 5x3 6L6 deluxe
If the 6.3VAC filament winding does not have a CT, then you need the two resistors, one from each side of the winding to ground, to create an artificial CT. They are typically 100 ohm.
ampmike
5x3build
Post by ampmike »
Thank you Martin,The transformer has a center tap.These values on the board are kinda hard to find 22uf/63 and 22uf /40.can they be subed for say a 25/50,then on the rectifier there is this 0.01 3kv,what is that?and I believe I will have to get a 270/20 watt.I have to do something diff at the end of the board for bias,correct?I'm going very slow here most of you guys would be done in a day or so. :oops: So if you guys can direct me to some of these diff value parts that would be great,Mikey
Re: 5x3 6L6 deluxe
http://www.mcmelectronics.com/product/N ... -/31-11596 has the 22uf/63v axial e-cap but you can sub 25uf/50v as well.
ampmike
Post by ampmike »
Thanks Mark,would you sub the 22/63 with the 25/50"s it would be nice just to get all three one shot.I want to get some good pots as wellThat one cap I assume on the rec tube pins 4&6 by the diodes.what is a 0.01 uf 3 v ,what's the 3v?Is that just 3 volts?
Re: Mark
ampmike wrote:Thanks Mark,would you sub the 22/63 with the 25/50"s it would be nice just to get all three one shot.I want to get some good pots as wellThat one cap I assume on the rec tube pins 4&6 by the diodes.what is a 0.01 uf 3 v ,what's the 3v?Is that just 3 volts?
The 22 vs. 25uF is no big deal, either one will do. The silicon diodes are backing up the vacuum diodes, and the cap is across the AC presumably to eliminate switching noise. It's shown as a 3kV rated part, but 2kV would be enough. There is an error on the Ceriatone layout in that the DC feed to the reservoir cap should come from pin 8.
Re: 5x3 6L6 deluxe
I looked at the layout and yuppers coming of pin 2 again.
Re: 5x3 6L6 deluxe
I looked at the layout and uppers coming of pin 2 again.
Ceriatone shows a wire going from rectifier socket pin 2 to the standby switch.This wire should be connected to pin 8.
ampmike
Pin 8
Post by ampmike »
Thanks guys,I'll switch that to pin 8 today,mike
