Fender Princeton reverb
Fender Amp Discussion
rdjones
Re: Fender Princeton reverb
Post by rdjones »
Blackburn wrote:Cool, man. I really want to use some in a build. Think you might want to sell me a few? :D
Unfortunately most are "non-Fender" values and voltages.
I'll send you a pm.
rd
badzuri
Post by badzuri »
Found the green wire from the reverb transformer was grounded under the screw that holds the tranny in place, it bit right through the plastic jacket. Fixed that problem and same thing, just buzz but if I tap on the pan I can hear the tank crash faintly in the speaker. Did I fry the reverb tranny?
Robert E Shumway
jelle
Post by jelle »
That is easy to measure with an ohm meter. :D
badzuri
Post by badzuri »
Got reverb working but has a buzz that gets louder that higher the reverb knob goes, if I unplug the send cable buzz still there, if I unplug the return cable buzz is gone. Any thoughts?
Robert E Shumway
badzuri
Post by badzuri »
Thanks to everyone the reverb buzz problem is solved, had the reverb tank in backwards now the amp is complete, quite as can be, super tone and lush reverb. Trem is also to die for, so a big thanks to all of the amp guru's that helped me solve several problems.
Robert E Shumway
badzuri
Post by badzuri »
Finished project
Robert E Shumway
Blackburn
Post by Blackburn »
Nice! :D
don280z
Post by don280z »
telentubes
Post by telentubes »
Pulled the Celestion Blue in my new BFPR build and swapped it for a Eminence "Swamp Thang" (brand new) I had gotten for a D style build but didn't use. I actually like it better.
