Well, I did it. I stripped the entire chassis and started in fresh. It's surprising how quickly they come apart compared to the time it took to put it together.
One change I made which was due to a rookie mistake, was to turn all the hardware around. I previously had the screws for the doghouse and OT on the outside and nuts on the inside. This really interfered with the placement on the board and made it next to impossible to remove the doghouse without removing the board.
[img:800:600]
http://www.crenshawweb.com/bassman/build42.jpg[/img]
While I had it apart, I fit the chassis into the cab...the one thing I forgot to do before it weighed 15 lbs. Much easier this way.
[img:800:600]
http://www.crenshawweb.com/bassman/build43.jpg[/img]
So, back to the rebuild. The first time around I was checking drawings, identifying parts, sorting out placement...just not focusing on the basics.
After some time with a solder sucker...love that thing...and then a wipe down with DNA and I'm ready to go.
[img:800:600]
http://www.crenshawweb.com/bassman/build44.jpg[/img]
Here are some shots that I should have taken the first time around that might have helped with trouble shooting.
Ground bus that runs along the front of the chassis. Anchored at the PT mount and floating on the other end...help in place by ground wires. Gain stages, pots and power tubes are grounded here.
[img:800:600]
http://www.crenshawweb.com/bassman/build47.jpg[/img]
[img:800:600]
http://www.crenshawweb.com/bassman/build48.jpg[/img]
Terminal strip also on PT mount. Earth, PTcenter taps, OT and filter caps are grounded here.
[img:800:600]
http://www.crenshawweb.com/bassman/build45.jpg[/img]
I added a 100K 2W bleed resistor to the filter caps.
[img:800:600]
http://www.crenshawweb.com/bassman/build49.jpg[/img]
I also adopted the use of my Stew Mac nut and saddle vise. It's heavy enough to hold the fully loaded board without tipping but light enough to move around with ease. One of the struggles I had in round one of the build was not having 4 hands...not usually an issue wiring guitars. By letting gravity and heat sinks hold things in place, I could really focus on the solder joints.
[img:800:600]
http://www.crenshawweb.com/bassman/build50.jpg[/img]
[img:800:600]
http://www.crenshawweb.com/bassman/build51.jpg[/img]
On the first build, I started at one end and just worked my way down. The large caps were a challenge when trying to tuck resistors under them. This time I did all the resistors first, keeping them low on the turrets. Then went back and added the caps keeping them on the upper slot of the turrets. It worked out great and was visually easier to reference what was where when I did a QC pass.
[img:800:600]
http://www.crenshawweb.com/bassman/build52.jpg[/img]
[img:800:600]
http://www.crenshawweb.com/bassman/build53.jpg[/img]
[img:800:600]
http://www.crenshawweb.com/bassman/build54.jpg[/img]
Peace,
