I thought there are other carbon film resistors which are non inductive.
https://www.hificollective.co.uk/sites/ ... _pdf_1.pdf
I agree with what you say. However, if there is a difference, then that difference should be able to be demonstrated. The high frequency response of a guitar amp isn’t that high, so surely most people would hear the difference. I think there is an attitude that carbon comps are different but no one can demonstrate it or replicate it. That does make me somewhat cynical to these claims. I’m not anti carbon comp and I look forward to be proven wrong about tonal differences but I have looked for videos and recordings showing the differences and it’s not happened for a long time.Charlie Wilson wrote: ↑Fri Sep 02, 2022 5:48 pm Bottom line, if you don't hear the difference, don't worry about it. However, that does not mean there is no difference.
CW
While the sound clips here do show one amp being noticeably brighter than the other, can this difference really be attributed to the caps? Are the amps really identical? For example, what if say one or more of the pots in a tone stack differed a bit from amp A and B. Something like that alone could account for what is being heard. There are too many variables that have not been fixed in order to isolate the change in "tone" being caused by just the caps.Mark wrote: ↑Sat Sep 03, 2022 10:52 am The link has a guy demonstrating the difference in Jupiter caps, so it’s possible to capture differences in components.
https://youtu.be/v0bOorfux-c
Signal going into the amp was from a looper of some kind, so the input signal is the same. I’m not too worried about the tolerance of the resistors and the pots as that will be +|- 5% to 10%, though caps have loose tolerances. The tolerance of the transformers is an unknown, I have never heard of anyone discussing the tolerances of a transformer.romberg wrote: ↑Wed Sep 07, 2022 3:54 am A more carefully controlled test would be to use a recorded DI signal for the input. Then record the amp with cap brand A. Then very carefully (without touching anything else in the amp at all) replace the caps with brand B. Finally record the same DI signal again using the exact same amp and setup for test A. My guess is that this would produce results that would be more difficult to tell which caps were which.
I'm sure most folks in this neck of the woods have measured pots. Have you ever measured a 25k pot (say for the mids on a tone stack) and found it to be 25k? They almost never are. They are all over the place. And that is just the end to end measurement. Now consider two "identical" pots at 50% of their rotation. The values you get will be even more off.
Around the 2 minutes in, the video shows a guitar being played in both scenarios?
Such as documenting a justification here why not to do it? FYI I have on good authority that certain members here are dreadful nose pickers
cheers,Charlie Wilson wrote: ↑Fri Sep 02, 2022 5:48 pm Bottom line, if you don't hear the difference, don't worry about it. However, that does not mean there is no difference.
CW
I had better things to do than chasing down circuits and building prototypes when the forum was still a Yahoo site, but I did it for the greater good. The forum you see here today is a result of people giving. Perhaps this is your chance to give to the forum.
ok respect..Mark wrote: ↑Wed Sep 07, 2022 11:11 am I had better things to do than chasing down circuits and building prototypes when the forum was still a Yahoo site, but I did it for the greater good. The forum you see here today is a result of people giving. Perhaps this is your chance to give to the forum.
https://tubeamparchive.com/files/Mark_R ... fo_cct.jpg
https://tubeamparchive.com/files/Expres ... iation.jpg
https://tubeamparchive.com/files/Expres ... rawing.jpg
https://tubeamparchive.com/files/liverpool_layout.pdf
In the comments you can see that I asked him that very question and he replies that he used a looper. The playing might be for content.
I personally tire of hearing this refrain. I'll show you a quote that shows you the timeliness of the 'youth of today' complaint:bepone wrote: ↑Wed Sep 07, 2022 12:31 pmok respect..Mark wrote: ↑Wed Sep 07, 2022 11:11 am I had better things to do than chasing down circuits and building prototypes when the forum was still a Yahoo site, but I did it for the greater good. The forum you see here today is a result of people giving. Perhaps this is your chance to give to the forum.
https://tubeamparchive.com/files/liverpool_layout.pdfthe young generation all want today something without any effort , so my comment was cumulative for all what i'm seeing last 5-10 years everywhere..open youtube and thats it..all is there.
practice is all what is count, here and in other hobbies/works,at least from my point of view and i'm seeing often philosophers.....
