Princeton Reverb build
Fender Amp Discussion
rdavy
Re: Princeton Reverb build
Post by rdavy »
peckjed wrote: Wed Oct 07, 2020 1:30 pm
Colossal wrote: Mon Oct 05, 2020 3:35 pm
peckjed wrote: Mon Oct 05, 2020 3:29 pm
What changes did you notice when you add the 470K? Ive got a 12" Eminence GA-SC64 sitting next to me waiting for the cabinet to come in.
The grid stopper drops voltage and keeps the cathodyne from getting hit so hard and folding like cheap lawn furniture, producing the horrible frequency doubling effect and nasty distortion. Bigger values will smooth that out without killing any tone. You might try a 1M pot there and dial it in to your taste and then replace the pot with a fixed resistor.
I added the 470K to the PI which made a nice difference. I also added the 1.5K and 470ohm screen resistor and grid stoppers to the 6v6's. Based on Robs layout (https://robrobinette.com/images/Guitar/ ... t_Mods.png) does it matter which end the wire connects to the grid on pin 1 or 5?
Yes, it depends which end the wire connects. In your most recent pic, it looks like you have your wire going straight to the grid and not through the grid stoppers first. Connect your wires at pin 1 so the signal passes through the 1.5K resistors.
ViperDoc
Post by ViperDoc »
rdavy wrote: Sat Oct 10, 2020 12:46 pm
Correct. Pins 1 and 6 are unused in a 6V6 tube. The stock layout shows the power tube grid wires coming off of pin 5. If soldering the power tube grid stopper resistors between pins 5 and 1, connect the power tube grid wires to pin #1. Check RobRob's "stock" layout here. Note that Robinette connected pins 1 and 8 in the stock layout to, I believe, allow for use of EL34 tubes:
And the modded one here. Note also that the modded power tube screens are rewired with resistors between pin 4 to pin 6, the leads coming off of pin 6.
Just plug it in, man.
peckjed
Post by peckjed »
Thank you! I made those updates this morning.
