reverb feeding back in new Princeton build
Fender Amp Discussion
norburybrook
Re: reverb feeding back in new Princeton build
Post by norburybrook »
well, thanks to @AmpMike at Modulus amplification, he had a new tank here for me today. Issue solved.
I also took the opportunity to as suggested by someone above to make a bag from the left over tolex, which will stop the dust and crap getting in there if nothing else :D
A happy ending to a strange issue.
M
didit
Post by didit »
norburybrook wrote: Mon Jul 15, 2019 4:37 pm unfortunately my donor one i had lying around was the wrong impedance.I think it had come from a solid state reverb in a tube amp.
Assume it's a Peavey "donor". There are tube circuits to mate higher input impedance of the 4EB2C1B.
For example -- http://www.channelroadamps.com/articles/reverb_driver/. Obviously different from stock Fender. Some might consider it an upgrade.
Presuming another MOD as replacement. Nice muffle bag too. How does it now sound over all?
Best .. Ian
norburybrook
didit wrote: Tue Jul 16, 2019 2:28 pm
Best .. Ian
Ian,
Yes it was peavey donor but the reverb was solid state. I did think about reworking things to make it work but as tanks are cheap i just went with the MOD fender one.
It sounds great now, no resonance and NO feedback.I'm sure the bag will help keep it all nice and clean and tidy in there.
I'll do a sound clip at some point I'm sure.
M
Post by Stevem »
It really helps to keep the spring end connectors from breaking if you glue some weather strip foam below the two springs near there center so that you limit there unneeded range of motion / flex in the springs when you travel with the amp.
Each spring is held in place on its ends by thin and very hard ( prone to braking) wire that goes into the 2 tubes on each end of the tank.
Note that if these brake I have worked out a way to fix that issue when can save a hard to get vintage tank!
norburybrook
Stevem wrote: Wed Jul 17, 2019 11:55 am It really helps to keep the spring end connectors from breaking if you glue some weather strip foam below the two springs near there center so that you limit there unneeded range of motion / flex in the springs when you travel with the amp.
thanks for that tip Steve. Next time it's apart I shall do that :D
M
