Calling Martin Bombay!
Fender Amp Discussion
ChopSauce
Re: Calling Martin Bombay!
Post by ChopSauce »
pompeiisneaks wrote: Mon Nov 05, 2018 5:29 pm I know he's not going to toot his own horn, but if you guys haven't checked out all of sluckey's stuff on his site, you're missing tons of great info www.sluckeyamps.com
You'll dig it! :P
~Phil
Nice !
Thx,
Bombacaototal
Post by Bombacaototal »
Indeed very nice website and very well documented!
And in conclusion
ALWAYS BIAS YOUR OSC WITH A RED LED
sluckey
Post by sluckey »
Unless you want to use yellow just to be different. Green and blue don't work so well.
You are awesome, Steve. You could use ultraviolet ones and make a thing do a thing. lol
Thanks for the thousand miles of blood. I followed your trail through 2000 posts all over the internet to arrive at this amazing conclusion. The vib circuit in my Bandmaster is fantastic now. The speed can't defeat the OSC in either extreme, the width of the pulse is over the top. It has 30% more than I like and started with 50% less than I could use.
That is just right!
sluckey
Post by sluckey »
I've used the LED in several other tremolo amps too. Different colored LEDs have different forward voltage drops. Some are suitable to bias a 12AX7 phase shift oscillator. Some are not. So, did you hide the LED or put it up front for the world to see how bright you are? :D
The LED idea is not mine. I think I borrowed it from Merlin. Scroll down to the bottom of this page...
http://www.valvewizard.co.uk/trem1.html
sluckey wrote: Wed Nov 07, 2018 8:27 pm I've used the LED in several other tremolo amps too. Different colored LEDs have different forward voltage drops. Some are suitable to bias a 12AX7 phase shift oscillator. Some are not. So, did you hide the LED or put it up front for the world to see how bright you are? :D
This is in a 62 Bandmaster and I am not about to spend time cutting a hole, although I considered wiring it into a rarely used input jack. lol (rarely used jack hole reserved for mid shift or slope)
It is the only way to warble. It's a whole different game.. it's crazy. I'm crazy. Perfect!
I'm old enough to leave my blinker on now.
This is what the amp does now. Les Paul and a wire.
https://www.dropbox.com/s/e2rwjh2tvrppp ... C.MOV?dl=0
ER
Post by ER »
That sounds fantastic, how long do you have to play it before you get your sea legs?
sluckey
Post by sluckey »
Well, you ordered more insanity. I believe you have arrived. :mrgreen:
Here's a bit of Hoffman doing some over the top trem and reverb with his revibe…
http://www.el34world.com/Misc/Music/fil ... eTest1.mp3
http://www.el34world.com/Misc/Music/fil ... eTest2.mp3
haha that reverb is NUTS! It sounds better than my stand alone thing... (looks at revibe scheme.. again..)
The most surprising thing about the LED is that the vib still works with the volume on 8. That's reeeediculous!
Also, whatsthedeal about the diode over the intensity! :D
sluckey
Post by sluckey »
Haha! Doug was just demonstrating how strong the reverb is with the revibe. He does some good surf tunes with insane reverb. The revibe can easily be dialed back for a more subtle reverb and/or tremolo sound.
The only place I've seen the diode on the INT pot is in the bias vary trem circuits, ie, the trem signal modulates the grids of the output tubes as found in the 6G16 Vibroverb and Princeton Reverb. The diode is to prevent a strong trem signal from "pumping" the bias too hard, creating a thumping sound from the speaker. I don't think it would be applicable to your bandmaster circuit.
sluckey wrote: Fri Nov 09, 2018 10:59 am The revibe can easily be dialed back for a more subtle reverb and/or tremolo sound.
Yeah, and I can get a ticket for 63 in a 55... but I'm going to get a ticket for 100 in a parking lot!
Wheeeeverb! ;)
I couldn't sleep. Been thinking all night about tearing up my reverb and also about putting a bright cap on the normal channel side of my Bandmaster. Need also to pad the input on the reverb so I can feed it line level. I'm manic about amps, again.
sluckey
Post by sluckey »
I believe you have a fever. Burning rosin is the only cure!
