Slight Hum vanishes when volume or tone cranked .
showbander
Re: Slight Hum vanishes when volume or tone cranked .
Well i added that shielded wire after using a chopstick there & getting more hum appearing when touched or moved ...so i left it in !
I will try moving away from filaments more .
showbander
seemed ok earlier when moving it about with choppy .
showbander
Hey Martin ,i just noticed i didnt connect the ground buss to the 0.022uf cap that then goes to pin 7 of the ax7.....(Circled)
showbander
showbander
my previous message wasnt suppose to sound snotty its our shitty English language here where we just sound angry all the time
I read it back and i sound like mr Angry ha.
Edit: Don't ground that cap.
Last edited by martin manning on Sun Apr 06, 2014 9:54 am, edited 2 times in total.
showbander
thanks martin ,i will get on the case tomo ! cheers again for your help
Er, the one circled is a coupling cap. If you ground it there will be no sound. I'm sure Martin didn't mean to tie that one to the bus.showbander wrote:Hey Martin ,i just noticed i didnt connect the ground buss to the 0.022uf cap that then goes to pin 7 of the ax7.....(Circled)
FIrestorm is correct! I had it right the first time, and it will be totally silent if you ground that cap. Sorry for the confusion, don't know what I was thinking!
Does the hum still come and go with the tone and volume control settings? How are the input jack and first cathode resistor grounds done now? Can you post a pic of that area?
How much hum are we talking about here?
If you turn all the controls down and hook up a AC voltmeter across the speaker, how many millivolts do you read?
How is your heater circuit grounded?CT? 100 ohm resistors?
showbander
cbass , hmm not sure tbh it is grounded , so the 2 heater wires run from pilot light and just daisy chain to the last ax7 ....
On the layout it looks like The Center tap of the heater winding is connected to the power tube catodes through a 100 ohm resistor.
Is this how you have yours wired?
If your PT doesnt have a CT you need to do the "artificial"one
showbander
yes that resistor goes to pin 8
some pictures would be helpful.
Double check that that resistor going to pin 8 is indeed 100ohm
