Twin Tweed 5F8-A with Reverb and Tremolo
Bombacaototal
I was thinking of a good way to add a reverb and a tremolo to a 5F8-A. I think the approach taken on the Fender Dual-Professional Custom Shop (schematic attached) may be a good way to go.
One would essentially plug the 5F8-A circuit after the return. There are topology similarities which make me assume this would work. It probably would work on Marshall JTM type circuit too.
Any feedbacks on this approach?
a j shaner
Re: Twin Tweed 5F8-A with Reverb and Tremolo
I have successfully put a passive patch point between the wiper of the treble pot and the entrance to the phase inverter/driver using a Switchcraft 14b jack and TRS Y cord plugged into a tube reverb.
Would probably also work with the ReVibe.
What about something like this? It would not be a true Twin Tweed with 5F8-A , but adding reverb and tremolo will change that anyway.
Perhaps this could be a nice sounding amp? I attached an Express SCH editable schematic where you can modify this to whatever you want.
This is a DRAFT idea and you'll need to check for errors.
With respect, 10thtx
I've put reverb and tremolo into a '5F6A' circuit before. I tried many variations over the course of about 18 months before I arrived at this particular configuration, and this was the most successful. It utilises an Allen Old Flame-style reverb insertion method. The combination of DC coupled pair in front of the tone stack and the reverb and bias-vary trem sound quite good if I say so myself. This could work equally well with a 5F8A circuit methinks (because the topology is almost the same as a 5F6A).
Bombacaototal
Thanks @tubeswell for contributing and for sharing your schematic. It indeed looks like it might sound great. Which model did this tremolo come from?
Thanks 10thtx as well. I love the 6g16 vibrato. Looks like a good idea as well
It was the bias trem configuration I settled on after several experiments on variants of 6G9/6G11/6G15Bombacaototal wrote: ↑Sat Apr 01, 2017 3:10 am Thanks @tubeswell for contributing and for sharing your schematic. It indeed looks like it might sound great. Which model did this tremolo come from?
That's a very fine schematic, sir. A great distillation of Fenderishness, very nicely documented.tubeswell wrote: ↑Sat Apr 01, 2017 2:26 am I've put reverb and tremolo into a '5F6A' circuit before. I tried many variations over the course of about 18 months before I arrived at this particular configuration, and this was the most successful. It utilises an Allen Old Flame-style reverb insertion method. The combination of DC coupled pair in front of the tone stack and the reverb and bias-vary trem sound quite good if I say so myself. This could work equally well with a 5F8A circuit methinks (because the topology is almost the same as a 5F6A).
Bombacaototal
Thanks a lot! I really appreciate the contribution and the well documented schematic as pointed out by xtiantubeswell wrote: ↑Sat Apr 01, 2017 3:16 amIt was the bias trem configuration I settled on after several experiments on variants of 6G9/6G11/6G15Bombacaototal wrote: ↑Sat Apr 01, 2017 3:10 am Thanks @tubeswell for contributing and for sharing your schematic. It indeed looks like it might sound great. Which model did this tremolo come from?
Did you use a fender blackface reverb pan?
This will probably work great for Marshall JTM as well
Yep I used a standard accutronics pan and Fender BF-style reverb transformer.
A JM45 circuit is the same as a 5F6A
Bombacaototal
Perfect. Thanks again for the generosity!
One more thing, did you create your own layout board? Or did you manage to fit into an existing (ie ab763, princeton)
I did my own layout.
Bombacaototal
If you want some inspiration for how to lay it out, look at the old flame layout
davebolden44
I recently added reverb to my 5f6a bassman clone. I just did a passive loop just like in a dumble, like somebody else said, right between the treble pot and pi. Then I just slapped a plush verbrator in there. It is currently my favorite sounding reverb and amp and I have two ab763s and a traynor reverb master. Cant say enough good about the verbrator, its definitely studio grade reverb. I also think that the fact that the loop comes off a cathode follower is helpful for the quality of the pairing. The unit itself is also a tube buffered loop and trem could be added that way via pedal.
Bombacaototal
Thanks for the suggestion Dave. I always add the passive loops on my amps and I will check the mentioned unit, although I really love circuits with reverb and tremolo, and will probably go on this routedavebolden44 wrote: ↑Sat Apr 01, 2017 8:01 pm I recently added reverb to my 5f6a bassman clone. I just did a passive loop just like in a dumble, like somebody else said, right between the treble pot and pi. Then I just slapped a plush verbrator in there. It is currently my favorite sounding reverb and amp and I have two ab763s and a traynor reverb master. Cant say enough good about the verbrator, its definitely studio grade reverb. I also think that the fact that the loop comes off a cathode follower is helpful for the quality of the pairing. The unit itself is also a tube buffered loop and trem could be added that way via pedal.
