In short I bought a used build of a deluxe reverb clone and wanted to change it to a high gain circuit that I really like with the following changes:
1) Single channel and no trem, therefore I'm able to make it really crunch and overdrive at high volume.
2) 45w output xformer like a Super Reverb or Bassman
3) Diode rectifier.
4) Changed V1 cathode bypass to a Marshall like 2.7k/0.68uf value.
The noise on this build is unbearable whilst the mod to these specs I did on my my original super reverb mod is great.
In terms of my grounding I note the following:
1) Input socket touches case to ground it.
2) All preamp grounds connect to bus wire going to input socket. This includes the cathode of the 20uf filter cap powering the preamp.
3) Cathode of another 20uf filter cap powering the PI goes to the same wire as the preamp ground.
4) All power amp grounds go to the same lug as the mains earth ground on the other side of the chassis.
5) I've experimented isolating the output sockets from the case and also where they touch the case. Neither makes a difference.
6) Power transformer has a centre tap wire which is connected to the poweramp and mains earth ground.
7) Secondary output xformer wires are being kept away from tubes.
I seem to have two horrible noises. One is the low end buzz and the other higher pitched one that increases when I increase the volume on the amp or guitars volume. I'm guessing I therefore have 60hz and 120hz hum going on.
For the life of me I can't work out what is going wrong. The only other thing I can note is the build does not have twisted heater wire, simply two flat buss wires (with rubber around them) running along the sides of all tubes. I am guessing since the original amp was a 2 channel blues deluxe it ran very clean and maybe noise was not an issue so not twisted heater wire was necessary.
Could you guys offer any of your wisdom with where the noises could be coming from?
Thanks for reading:)[/quote]
