5f2a-ish build
Fender Amp Discussion
stretch2011
Re: 5f2a-ish build
Post by stretch2011 »
Yes! You needed to put two 100 ohm resistors to ground to make an artificial center tap
johnnyreece
Re: 5f2a-ish build
Post by johnnyreece »
stretch2011 wrote:Yes! You needed to put two 100 ohm resistors to ground to make an artificial center tap
Yes, that should do it. Good catch!
goldenGeek
Re: 5f2a-ish build
Post by goldenGeek »
Yes!! I will try that because the old trafo fits a lot better into the chassis than the one that I put in today. I don't know why this didn't occur to me - I've read about artificial CTs a dozen times the last few years but never had to do it before...
goldenGeek
Re: 5f2a-ish build
Can that be done to the secondary high voltage or am I better off with full wave rectification?
Re: 5f2a-ish build
Absolutely not. If the HV secondary doesn't have a CT you have to use a bridge rectifier for full-wave rectification.
goldenGeek
Re: 5f2a-ish build
I finally got to try the artificial CT, 100R to ground, and the amp was incredibly quiet and good sounding... for a minute or so. The transformer started to get really hot so I had to shut it down. Can it be that this transformer is not good enough to pull this trick off?
JazzGuitarGimp
Re: 5f2a-ish build
Post by JazzGuitarGimp »
goldenGeek wrote:This brings me back to think about the first transformer... that one had a CT on the secondary, but not on the 5V or 6.3V. Could that be the reason this noise was there? Should I have used rectification and DC-heating?
You could use an artificial canter tap: use two 100R, 1%, 1W resistors. One resistor goes from one leg of the heater to string to GND and the other resistor goes from the other leg of the heater string to GND.
goldenGeek
Re: 5f2a-ish build
Yes, that was what I did (I used 3W resistors though) and the noise was completely gone with that fix, but the transformer got really hot and started to smell burned... so I guess my transformer can not handle this?
