Thanks for all of the help! I'm going to start specking this out and will hopefully take the plunge shortly thereafter. I do have one extra hole in the Princeton Reverb chassis face after Treb/Mid/Bass/Bright Switch/Volume. Might a "boost" switch for 2 or 3 different cathode bypass caps on the input signal (perhaps one with no cap) work on this circuit? Otherwise, might the caps and resistors added to simulate the loading effect of the vibrato be worth putting on a switch (simulated load or bypass direct to PI)? Would that difference be anything other than turning the volume knob up or down?
Thanks again!
Joe
Normal Channel Only BF Super Reverb Build?
Re: Normal Channel Only BF Super Reverb Build?
I did the same sort of build but I used a BF Fender Twin . I also used Baldwin Organ iron and the chassis as well.
Keith
Keith
