5f6 clone with reverb?
Fender Amp Discussion
Markusv
Post by Markusv »
Folks
I have someone who would like me to add reverb to a 5f6 clone
Where would one insert it? Planning to just do the standard deluxe reverb schem but given that the tone stack is driven off the cf and then straight into Pi I'm not sure if it will work before the tone stack and after cf
please help?
Markus V
.........Now where did I put it?
Re: 5f6 clone with reverb?
This is how Pete (tubeswell) did his 5f6.
https://tubeamparchive.com/viewtopic.ph ... sc&start=0
Markusv
Post by Markusv »
Thanks Mark!
Yes-looks like he inserted a gain phase just before the PI
Which is exactly what I was wondering about.
Keen to hear what it sounds like!!
Markus V
The music link is shown in that post I showed but I could never get it to open on either forum noted.
maybe Pete will show up and post a direct link if not I can email him.
Richie
Post by Richie »
Worked on a Holland amp years ago, it was a bassman type amp used 2x12 and 1x10. The 2x12 were fanes. The 10" was for the reverb.
Basicly it had mounted in the bottom of the cab was the fender type reverb,and you could control the amp from there,and the 10" was for the reverb. You might be able to look up some info on that amp. Just different ideas to look at.
Markusv
Post by Markusv »
Thanks folks to all of you who responded
I ended up using 10th TX's schem I found in the link
Keeps the amp very Bassman - standard. I would like to avoid a extra gainstage after the reverb if possible, but I'm open to opinions. Hopefully this approach provides good reverb.I'm no surfer dude so I really want modest reverb
M
For modest reverb use short reverb pan, it's very subtle reverb with the smaller pan.
