Bad Bob Boost
stratcat62
Bad Bob Boost
Post by stratcat62 »
Have any of you guys tried it? It's a clean boost that adds a little grit to the tone. I absolutely love mine. I use it to completely drive the front end of my Twin. I set the Twin on 3 and set the boost on Max and the result is the greatest tone I have ever heard. I may get some flak for this, but definitely a SSS vibe to it. Clean when played lightly, slightly driven when hitting the strings with some force. It blows away most other clean tones I've heard. You should definitely check it out. Now all I need is an attenuator.
Re: Bad Bob Boost
hehehheh, sounds like the clean channel on a D amp. :D :lol:
Always nice to find that piece of gear that gets you there! :D
stratcat62
Re: Bad Bob Boost
Ya, it sounds incredible. The only problem is that the volume level is knocking pictures off of walls and other items off of shelves. Attenuation seems to be my best bet.
