I saw this today and thought it might be of DIY interest. He makes a jig for 16ga steel boxes without a brake. I imagine it would work equally well for aluminum. You'll need some shop equipment, but no specialized tools. If you intend to only do it with aluminum, probably the only power tool you need is a wood working circular saw. A table saw would give better accuracy for making the jig.
https://www.youtube.com/watch?v=yrb1Oh0aJM4
Easy way to make a chassis
Re: Easy way to make a chassis
how difficult is to get chassis theese days, i think i will build bending press for metal sheets and finish the story
Well... that's a useful procedure.... making the tiny grooves where you want to fold is a very good idea.. steel or alu is just the same...
Cheap or home made brakes will almost always have accuracy problems.....
But of course... take your time, be accurate - or make a really good and accurate break..
