David Root wrote:Octals I use Belton Micalex, although I am getting some QQQ sockets (Japan) from Parts Connexion to try out.
QQQ are my favorite and they don't need a 30mm hole like the Beltons so they fit my English punches - traditional 1 1/8 IIRC. They are a lot like the old McMurdos except black. They can be mounted from the top or bottom, however for some really careless reason they are a tiny touch bigger from one of the directions, I think top, and you need to work the hole with a quick pass of a dremel or file. Beats me the Japanese are more typically on the ball.
Never, ever buy the cheapest generic plastic octal sockets (the $2 ones) no good for tweakers, the pins loosen up after a few pulls. I hate ceramic octal sockets, only time I've ever broken key pins on tubes, and only time I've ever had trouble inserting a 9 pin tube was on ceramics - some sort of slightly different ruskie/chinese standard. NOS ceramics are ok and maybe something like the Audio Note ceramics are fine but otherwise you never really know with modern ceramics what you'll get.
I too was surprised what the current rating was for 20awg and I may stop using 18 on the power tubes. As an amateur I haven't seen that much but I've only seen filament leads burn up right off the PT, never in the string along the sockets. Maybe the techs can verify.
