I've been hanging around here for a while now, lurking, and watching and I've noticed that some of you guys have amazingly straight leads on your components. Mine always seem to have a natural curl. I usually fight and get them adequately straight, but it always seems less then perfect.
What's the secret? How do you straighten the leads on your components? Is there a special hidden technique, a tool, or do you just have a collection of saucy schematics that lets nature take its course?
Generally, the resistors aren't too bad. Since I tend to buy them in quantity, they tend to be pretty straight right off the spool. It's the various caps that always make it challenging. Bigger electrolytics especially. They usually come with the leads wrapped around themselves, tied in knots, intertwined in some form of electronic kama sutra... Even small mallorys can be a challenge.
I look at some of the pictures of board layout - especially some of the marshall-style builds - and begin to get a complex.
When using turrets just wrap one end and pull tightly as you wrap the other side with needlenose or better yet hymostates , I also take a rag and clean the leads before hand puling from the center outwards until the leads are nice and clean and strait. I've found it best to wrap everything and only use the hole in the top of the turret if I #uck up, I also have a little tool its pointed on one end and the other end is also pointed but has a slot that grabs the parts leads or wire so you can guide it around I don't know what it's called but it's a godsend, the pointed end works good too make a little extra room in the holes in the pins of a tube socket or a pot. mark
Mark,
Is the "godsend" slot kind of like the eye of a needle?
I would LOVE to see a picture of that (and hopefully a name if someone knows) as I have often thought that kind of tool would be a ...well....godsend!!
Well here it is, its kina cool I can grab a wire and feed it through a tube socket pin hole then grab it from the inside and neatly turn it around the pin for a nice connection, I use the pointy end if I need to feed a wire or lead into a hole but there's no room I just poke in the hole and twist back and forth till I get a big enough gap, I have no idea what it is called I got it from a estate sale the guy was a repair man and had a 50 yr collection of stuff I go all kinds of kool stuff mark
