[img:240:238]http://farm1.static.flickr.com/193/5102 ... d62f_m.jpg[/img]
The motors run on 120VAC. It uses a 24V relay to switch speeds. There is also a 6V(?) incandescent bulb that works with two LDRs and an eccentric wheel that the organ used for additional tone shaping.
I have a 25.2VAC transformer for power. I want to power the relay, add a power on LED, and an LED that mimics the rotational speed via the lamp/LDR.
(To demonstrate my lack of electronics knowledge...
[img
I'm only getting ~19VDC after the FWR. I was thinking a FWR should produce (25.2-0.7) x 1.4 = 34VDC, but I guess Vpeak is only 12.6 so I'm only getting about half of that. Does that sound right? I think the current draw of the lamp, etc. is swamping the voltage divider, as well.
So, how can I get this up and running? Maybe a voltage doubler to get enough DC for the relay? Should I run the lamp from the main DC supply rather than the voltage divider because of the current draw? Then I could run just the LEDs from the voltage divider.
I know, this will never sound like a Leslie, but it was free. Should be fun for bedroom levels or maybe recording.
