Guitar Gallery Thread! Post 'em up!
studiodunn
Re: Guitar Gallery Thread! Post 'em up!
Post by studiodunn »
xtian wrote: Thu Aug 01, 2019 1:56 am Nice!
I just traded my Monkeymatic Trinity #2 for a Carvin TL-60. Love it!
Those are killer guitars!
10thTx
Post by 10thTx »
Strictly a hobbyist. Figured maple over Prima Vera which is a white mahogany that has some similarities in weight and tone to swamp ash (which I've used on other guitars).
Analine dye was used. Yellow, then amber, then red mahogany with deep red wine mixed in. It always looks quite faded and washed out until lacquered. The lacquer enriches and intensifies the color. I typically spray 21 coats and sand after every 7 coats. I've used Deft Clear Wood Finish on some and Minwax spray gloss lacquer on others which this one will have.
I use rags for the dye (not sprayed). I used Meguirs Ultimate (car) Polish to polish out the finish.
With respect, 10thtx
statorvane
Post by statorvane »
Very cool! 8) beautiful actually. I especially like the HSH body with the Tele headstock. Looks like a real rocker.
10thTx
Post by 10thTx »
Finished guitar. VERY musical woody percussive tone. Super happy with it! I think this is a guitar, just cord, just amp type tone.
I had trouble getting a good photo of it as the top is so glossy it would get light reflections in it.
Colossal
Post by Colossal »
Very nice!
That is exactly my jam, man. Semi-hollow Tele-style, humbuckers, one volume, one tone, fixed bridge. Beautiful guitar!
stelligan
Post by stelligan »
10thTx wrote: Mon Jun 29, 2020 9:16 pm Finished guitar.
Badass Strelecaster thinline...... :!:
bigsmitty
Post by bigsmitty »
TUBEDUDE
Post by TUBEDUDE »
10thTx wrote: Mon Jun 29, 2020 9:16 pm Finished guitar. VERY musical woody percussive tone. Super happy with it! I think this is a guitar, just cord, just amp type tone.
I generally see it as a crime without a single in the bridge, but that middle tele could change my mind. Good work man!
statorvane
Finished this one almost two years ago. All ash body, top & neck. I've seen ash (swamp) LP studios before, but not with an ash neck. Thought I'd try that and fit an ebony fretboard, and Stew Mac double action truss rod. Ash seems to be more sensitive to humidity changes than maple or mahogany. Black grainfiller, sealer and clear lacquer. Black binding w/all black hardware. I worked some weight relief into the body but it still weights around 10 lbs.
Originally had cream GFS crunchy rails. Way too hot. :shock: If you play in a band where the vocalist sounds like he is puking at volume 10 then these are your pickups. Swapped them out with Duncan hot rod set; still too hot (bridge) for me. Wound up with GFS Alnico II PAFish PUs. Pretty good pickups. Wired out of phase. Fun to play.
I think I posted it earlier but in keeping with my guitars in the grass theme with my mono 61 355.
The coolest thing is the serial is the year. Hah!
ChopSauce
Post by ChopSauce »
How beautiful is this !
(looks like I'm dreaming)
And the 66 lefty from the same spree.
jabguit
Post by jabguit »
cheers,
Jack Briggs
Briggs Guitars
didit
Post by didit »
Hello --
Fine looking 335-style, which evidently you built?
Recent addition of a 1948 L-48. Came lightly electrified, with semi-permanently mounted DeArmond monkeystick wired to a volume pot on the pickguard and a jack on the side of the lower bout. Removed for the moment as repairs necessary to both the guitar and electronics.
Best .. Ian
