becareful the volume issue can cause damage.
the reason the IEM are safe is that you can turn them down. If you are blasting them to keep up with a loud room / stage it can cause serious damage fast and you might not know it until it's to late.
start with both IEM in get your comfort level and when you take one out don't reach for the pack or ask for more volume. get used to it and setting in ... learn to listen.. if the room is to over powering put the both IEMs in or tell the band to turn down.
NO show is worth loosing your hearing (PERIOD!!!)
Is "In Ear" monitoring from the Devil?
Re: Is "In Ear" monitoring from the Devil?
My Daughter Build Stone Henge
