@cobalt: yes, runs on any machine that can run java 1.6 or newer
@Ian444: do you get any error? what are you trying to do and can you post the application log (can be found in log folder)
@selloutrr: just overwrite the old version and you should see tube sockets under Tubes tab.
I need further clarification on some issues:
Can't save - did you try File/Save?
Can't import template files from the library - I don't follow.
Component orientation - it would be nice to be able to flip polarity. Do you mean capacitors? When you create them, first click is for positive, second for negative leg. If you want to flip the polarity you can just drag control points around.
I'll add the other point to my to-do list.
Cheers
