wagner safe-t-planer alternative
Mat Cortex
Post by Mat Cortex »
Hi
For all the luthier and cabinet maker out there, here a link to a Wagner Safe-t-planer alternative :
http://www.cmtutensili.com/show_items.asp?pars=RB~852~2
That's a 35$ router bit that's made by CMT 1½" dia. x 5/8" with ½" shank.
Even cheaper than the safe-t-planer (discontinued) but with better result. Just make sure your press drill RPM is very high.
For those who don't know the safe-t-planer, it's a tool that many guitar making book recommend. Even Bennedetto ( famous jazz guitar maker ) use that on his own model.
Cheers
Mat
1965 Gibson Falcon GA19-RVT
Re: wagner safe-t-planer alternative
I gots an alturnutive to oneathem I calls it a be!tsander
Aurora
Post by Aurora »
Router bits usually usually needs moreRPM than a drill press has, but may be OK......
A router sled on a tray is agood alternative....
Here's another alternative.... almost as Wagner's....
http://durotools.com/DRILL-PRESS-SAFETY ... 11297.aspx
There may even be others....
EDIT: Sort of knew I'd seen it somewhere else, too....
http://woodworker.com/drill-press-planer-mssu-24760.asp
Mat Cortex
Aurora wrote:Router bits usually usually needs moreRPM than a drill press has, but may be OK......
CMT recommend 10 000 RPM, but it worked fine on my press drill at 3200 RPM. Anyway, I only use this for rough shaping and always finish with sand paper.
Router sled on a tray are great and when i'll want a nice setup I'll already have the router bit !!!
i've read mixed review on wagner's clone ( sandcast vs machined from billet, etc...) that's why I dont went for this option, and a router is on the top of my wishlist.
Regards
Mat
vibratoking
Post by vibratoking »
Besides RPM limitations, I don't think the bearings on most drill presses are rated for that kind of torsional force. Drill presses are not designed like mills and I have seen quite a few drill presses succumb while being treated like a mill. That being said, all may be OK with wood.
Mat Cortex
I totaly agree with you Vibratoking,
I've learn that those kind of tool only take light cut (max 1/16 depth), dont' push too hard and let the tool work. For me it's the ideal tool for making guitar neck taper,back of the headstock, brace ...etc. That's nontheless a great tool for limited space shop like mine.
Cheers
Mat
