It's my package.....
HeeBGB
Site Admin
Post by HeeBGB »
from Tube Depot. $120 really doesn't buy much these days. No bacon for me I can't afford it anymore.
sliberty
Re: It's my package.....
Post by sliberty »
That subject almost kept me away...so glad it was a photo of vacuum tubes. Otherwise I might have been damaged for life.
HeeBGB
Site Admin
Post by HeeBGB »
sliberty wrote:That subject almost kept me away...so glad it was a photo of vacuum tubes. Otherwise I might have been damaged for life.
Don't sell yourself short. You ARE damaged but not cause of me.
vibratoking
Post by vibratoking »
bacon before tubes...there, I said it.
NickC
Post by NickC »
A bit of cautionary advice ....... only fry bacon on the valves in your amp with the chassis being a tubes-down type. Trust me on that.
selloutrr
Post by selloutrr »
I'd let my tone suffer for good bacon :)
You are lucky you got that many tubes for $120
My Daughter Build Stone Henge
Blackburn
Post by Blackburn »
I tend to buy JJs more than anything else, new production wise, but I'm curious about the Sovtek EL84Ms. Since I saw they're used in the SW30, I've been wanting to give them a go. The 12AX7 Long Plates as well. The JJs just put up with beatings so well. :)
Them minnites or amish or what ever you call them Can cure the shit out some bacon.I'll never take our hogs anywhere else.Its the best bacon i ever had anywhere by far
Zippy
Post by Zippy »
Wrap the bacon around the EL84s and run 'em hot.
Mmmmmmmmmmmmmmm...
Blackburn
Post by Blackburn »
Bacon wrapped vacuum tubes... Yes.
I think these should be served at an amp meet. :D
Zippy
Post by Zippy »
Maybe it's lunch time and I'm hungry, but I'm thinking this could work. Just need to put a drip pan in the bottom of the head cab...
NickC
Post by NickC »
Zippy wrote:Maybe it's lunch time and I'm hungry, but I'm thinking this could work. Just need to put a drip pan in the bottom of the head cab...
That's what the reverb pan is there for. Catch the drippins' in the 'verb pan ..... and enjoy that Dick Dale bacon-dripping-surfadelic tone. :wink:
JazzGuitarGimp
Post by JazzGuitarGimp »
I say mount eight KT88's sideways with no space between them. Then lay the bacon strips across them length-wise!
Zippy
Post by Zippy »
JazzGuitarGimp wrote:I say mount eight KT88's sideways with no space between them. Then lay the bacon strips across them length-wise!
Now you're headin' toward barbequing capability. 8)
