Ecl82
Ecl82
Hey guys ,Im going through my tubes and found a strong set of ECL82 Brimars.Would they be compatable for el 84's?Thanks Guys,Mikey
- VacuumVoodoo
Re: Ecl82
The answer is in the datasheets.
http://www.mif.pg.gda.pl/homepages/fran ... /ECL82.pdf
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
Re: Ecl82
they do look like el84 on paper but I read a few times about them being too bright or something...sounding bad in general. Try searching on ax84
Check out my site with DIY gutars, amps and pedals http://diy-fever.com
- VacuumVoodoo
Re: Ecl82
ECL82: a triode and a pentode in one bottle
EL84: single pentode.
They look alike?
Even if you compare only the pentodes there's no similarity neither in physical appearance nor in electrical specifications.
They look alike?
Aleksander Niemand
Zagray!-review
Zagray!-review
Thanks Man,I really appreciate the info.I stumbled apon a amperex EF86 and put it in my brownote build yesterday,Wow! Big difference.Thought maybe I could use the 82's in something.Thanks again,Mikey
Re: Ecl82
But they both have an E and an 8 in them
Re: Ecl82
Mikey, as Aleksander said, they not compatible to EL84 tubes.
Don't listen to any internet armchair experts about tubes being boring or something, put the Brimar ECL82 in a late fifties Dynacord KV10 and you will have those guys cowering behind the sofa.
Re: Ecl82
FWIW the ECL86 has an EL84-like pentode inside the envelope (and a 12AX7-like triode).
The ECL82 has a pentode but it is slightly lower-powered than an EL84, and the triode is more like a 5751 AFAICT
Cliff Schecht
Re: Ecl82
Not ax7 like, closer to an AU7 iirc.. still a great triode/pentode combo fwiw..tubeswell wrote:FWIW the ECL86 has an EL84-like pentode inside the envelope (and a 12AX7-like triode).
Cliff Schecht - Circuit P.I.
Re: Ecl82
ECL82 is the same as the 6BM8
http://www.duncanamps.com/tdsl/show.php?des=6BM8
I used that tube to built a mini-bassman and it works well as a low power (~~7w PP) studio amp. I used the triodes for the LTP inverter & an 8k (or 6.6k.....can't remember) Deluxe-type OT.
http://www.el34world.com/Forum/index.php?topic=562.0
All the guitars on the following link are the above mentioned amp.
http://www.musicwebtown.com/jallenshaw/46763
There are 2x different clips of the amp on the "playlist" @ that link......"Spanky Blues 6BM8" and my personal favorite, "Smooth Hot Potato"
