Gimme 1 ohm resistors to ground on a fixed bias setup and I'm good...but then there's no math in that.
Thanks.
I suppose it must drop for high plate voltages , GEC 6V6 GTA spec it for class AB1 at Isc idle = 5mA and 4ma for Vp= 250V and 285V respectively (Vsc=Vp)tubeswell wrote:<snip>
The screen current is only about 2mA tops (not 5mA) in those things.
<snip>
I reckon that is just a conservative number new sensor put in there. My experience with them is about 2mA tops. I have tried them in a couple of amps last year (a 5G9 and a 5F2A), but have since gone back to JJ6V6s. The screen support rods are quite piddly in the 'Tung-Sol' RI, and I am now a bit dubious about their longevity - after 9 months or so they started to crap out with the tell-tale static and buzzy noises. Still, they sound okay when they are new. Using a beefier cathode resistor in cathode bias is probably not a silly idea for these tubes.Ears wrote:I suppose it must drop for high plate voltages , GEC 6V6 GTA spec it for class AB1 at Isc idle = 5mA and 4ma for Vp= 250V and 285V respectively (Vsc=Vp)tubeswell wrote:<snip>
<snip>
But that's for two tubes I guess.
solderstain wrote:Good thread!
Cathode biasing (of power tubes) is a subject that I'm becoming more interested in from a design stand-point. I've done a handful of builds where I've just built an example of someone else's design, but I'm growing past that...
So, all you guys with the large brains (or more years of schooling than me...):
What's the math to calculate the value of a cathode resistor necessary to arrive at a desired dissipation? Here's a place I can find myself:
A 2xEL84 amp, with 12AX7s in the front end. Building it into a gutted chassis of another manufacturer and reusing the original iron. With a given power supply voltage string and filter structure, I'd know what the plate voltage is likely to be. And it will be lower than what is considered 'normal' for the average EL84 application.
Since I know the tube characteristics, and I have a good idea what plate voltages I'll have, how do I arrive at the value of the cathode resistor?
I'm sure it's common math to most of you, but it's new to me. I don't want to just throw a bunch of different resistors in there until I arrive at my goal. I'd like to have a damn-close ball-park idea of what I need before I heat up the soldering iron.
And.... a similar question about the attending capacitor: how does one arrive that the 'best' value for the cap? Is that pretty-much up to experimentation and what my ears like?
Right now, I'm more interested in the math for calculating the cathode resistor value, though.
THANKS IN ADVANCE!
DUDE, an Excel model would be killer. I used to have something like that, but it won't work with my latest Mac software (I think the older one I had was from '97 or before...).thepacifist wrote:AFAIK, the cathode voltage is to be decided from the datacharts on the basis of desired bias right?
If yes, let me know. I have a excel model for this ready which I can put up here and can be tweaked as per inputs from experts.
pacifist
THANKS IN ADVANCE!
AMEN! Post that sucker!dehughes wrote:DUDE, an Excel model would be killer.
