fuchs ods 50
mr.lp
fuchs ods 50
Post by mr.lp »
serial is after 500 so it's an slx. seems a little bright and thin. does any one have any suggestions on warming or browning the sound a little?
i play an 89' strat and a new tele with seymour duncan pg's and 57's that
split into single coils. both are strung with 10's. the amp is stock.
Guitarman18
Re: fuchs ods 50
Post by Guitarman18 »
mr.lp,
If you ask this question over at Dumble discussions you are more likely to get the answers you are looking for. Also Andy Fuchs is a member there and from time to time drops in on Dumble discussions.
Paul.
Kregg
Re: fuchs ods 50
Post by Kregg »
What speakers are you using? I run mine through both a Celestion loaded 212 (divided by 13) and a THD 212. Humbuckers sound great into both set ups. However, my Strat sounds best with the ODS 50 hooked up to the THD cabinet. Even if I flip the brite switch on it doesn't sound as harsh as when I play it through the Celestion loaded cabinet.
"A man with an experience is never at the mercy of a man with an argument." Hilmar von Campe
