Heaters/Filaments, Centre Taps and Current Draw
frequencycentral
Post by frequencycentral »
Last edited by frequencycentral on Mon Apr 12, 2010 5:50 pm, edited 1 time in total.
paulster
Re: Heaters/Filaments, Centre Taps and Current Draw
Post by paulster »
It's easier to convert into watts for each filament, add them all up, and then work out a current consumption from your composite power consumption figure.
In this case you'll end up with 12.6V/300mA.
If you look at the 12AU7 example you'll find that you can have 6.3V x 0.3A = 1.89W or 12.6V x 0.15A = 1.89W. The power consumption is the same regardless of which way you wire it.
In your case each tube is 6.3V x 0.3A = 1.89W
Total power consumption for 2 tubes is 2 x 1.89W = 3.78W
Divide that by 12.6V (nominal supply voltage) and you get 0.3A.
frequencycentral
paulster
Post by paulster »
I'm impressed. It's not often Maplin sells something that even meets, let alone exceeds, the published specifications!
gearhead
Post by gearhead »
Alright, I am now confused.
Being a bit parochial, what would the current draw be for a Liverpool and an Express?
3 X 12AX7
4 X EL-84 (or 2 X EL-34)
Tell me if I got this right:
For Liverpool,
12AX7: that's 1.89W per heater times 6 heaters = 11.34W
EL-84: that's .76 A x 6.3V = 4.78W, times 4 heaters = 19.1W
Total is 31.44W. With a nominal power of 12.6v, current is 2.5A
According to this table: http://www.powerstream.com/Wire_Size.htm
I'd need to use 16ga to be safe. However, I know lots of folks here that use 20ga?
paulster
Post by paulster »
You only need to calculate 3 12AX7 heaters since the current consumption figures have already considered whether the filaments are in series or parallel for 6.3V or 12.6V operation.
Since you're running everything at 6.3V in an Express or Liverpool you can simply add up the current figures.
Liverpool: (3 x 0.3) + (4 x 0.76) = 3.94A
Express: (3x 0.3) + (2 x 1.5) = 3.9A
I'm not going to calculate wire gauges because we don't really use them in the UK, just current ratings on our wire. Just bear in mind that the preamp tubes can be wired with smaller wire than the power tubes because their cabling only needs to carry their filament current, assuming that the power tubes are wired to the PT and then the preamp tubes follow these.
ChrisM
Post by ChrisM »
Hey Rick (kurtlives from DIYStomp)
I am pretty sure the 12AU7 draws 300mA per current when run at 12.6V DC using pins 4 and 5? Or are you talking about 150mA per triode?
150ma @ 12.6v and 300ma @ 6.3v.
Voodoo_Man
Post by Voodoo_Man »
paulster wrote:I'm not going to calculate wire gauges because we don't really use them in the UK, just current ratings on our wire. Just bear in mind that the preamp tubes can be wired with smaller wire than the power tubes because their cabling only needs to carry their filament current, assuming that the power tubes are wired to the PT and then the preamp tubes follow these.
My real 1966 Super uses AWG 20 (.032 in.) solid wire for all the heaters. Cloth of course. It actually measured .033 in. Close enough.
God Bless,
"Arnold, where's my tax refund???"
Voodoo_Man
gearhead wrote:Alright, I am now confused.
Only if you wire a cigarette lighter & air horns in the circuit too. 16 is way over kill. As I stated in another post, my super reverb uses 20 for all the heaters. That's 1 x 12AT7, 4 x 12AX7, 2 x 6L6, and the GZ34
God Bless,
Jana
Post by Jana »
Well it never hurts to plan ahead for future expansion!
Voodoo_Man
Well, it'd be a blow dryer & curling iron in your case. Aren't those current hogs? Or maybe some AWG 8 for an arc welder.
God Bless,
john
frequencycentral
Last edited by frequencycentral on Mon Apr 12, 2010 5:51 pm, edited 1 time in total.
frequencycentral
paulster
Post by paulster »
Use V=IR (R=V/I) to figure the resistance of each heater at 6.3V using the tube data for the heater current.
Then you'll be able to calculate the resistor to put in parallel with the higher value resistance to make both the same, at which point they'll get half the supply voltage each.
This will result in power being dissipated in the resistor as heat though, so it doesn't really help to minimise your overall current draw.
