What's in this box?
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... NA:US:1123
Matchless stereo mixer buffer
- skyboltone
Re: Matchless stereo mixer buffer
The two ECC83s are probably arranged as virtual-earth adders, cascading into a a third adder for Y mode, maybe with the 4th triode as an output buffer, or maybe an output boost stage or something.
- skyboltone
Merlinb wrote:The two ECC83s are probably arranged as virtual-earth adders, cascading into a a third adder for Y mode, maybe with the 4th triode as an output buffer, or maybe an output boost stage or something.
Dan
- Noel Grassy
A Virtual Earth Adder also sounds like a Computer Generated Viper that dwells underground.
I bet Steve Irwin would've tackled one.
It's when you apply lots of local feedback to a stage, and a series of channels are fed to the stage via input resistors. Think of an op-amp arranged as an inverting amplifier, it's the same things.skyboltone wrote:Merlinb wrote:The two ECC83s are probably arranged as virtual-earth adders, cascading into a a third adder for Y mode, maybe with the 4th triode as an output buffer, or maybe an output boost stage or something.![]()
Thanks Merlinb. What do you suppose the american for virtual earth adder is? Sounds a bit like the magician explaning one trick by performing another!
Dan
- skyboltone
Thanks. That does help.Merlinb wrote:It's when you apply lots of local feedback to a stage, and a series of channels are fed to the stage via input resistors. Think of an op-amp arranged as an inverting amplifier, it's the same things.skyboltone wrote:Merlinb wrote:The two ECC83s are probably arranged as virtual-earth adders, cascading into a a third adder for Y mode, maybe with the 4th triode as an output buffer, or maybe an output boost stage or something.![]()
Dan
