Amp advice - I'll build for a friend
fabiomayo
Post by fabiomayo »
Hi, guys.
I want to build an amp for a friend. I'll use a 2x12" combo cabinet and
50w (2xEL34 or 2x6L6) trannies as a building foundation. The PT is
locally made, the OT is Allen Amps TO-60
What can I build that'll offer a good basic clean tone and some marshally
crunch (ACDC rhythm style)?
I realize it's a tall order but I'm really a novice to this kind of amp and
wanted to please my good friend.
AdrianJ
Re: Amp advice - I'll build for a friend
Post by AdrianJ »
Well, my suggestion would be a Marchall JTM45 type amp. There are a few kits available and they all look fairly simple (as amps go!!).
I'm a novice at this myself and am planning my first amp build which is going to be a Fender 5E7 type circuit, yet to decide what speaker config to go with - tempted to build the amp in a head and then get both a 3x10" and 2x12" cab built for it - fender tweed stack!!
If that goes well then I'm gonna throw myself in at the deep end with a D-type amp!! (If not then I'll get someone to build the d-type...might do that anyway cos I'm impatient!!)
You're onto a great community here though and there's some extremely knowledgable people here.
fabiomayo
Post by fabiomayo »
Thanks for your reply. I figured the JTM45 could fit the bill. But how's the
clean tone? It's important to have the ability of really clean, funk grooves.
I was gravitating between a Marshally design or Fender with extra features
for overdrive (maybe a second preamp, Marshall).
I already built a couple of amps for myself but was never interested in
that kind of tone. I've built a Champ and an ODS.
AdrianJ
Post by AdrianJ »
Well I've never played a proper JTM45 myself, but they're supposed to have the best clean tone out of any Marshall. Don't forget they are basically Jim Marshall's take on the Fender Bassman.
fabiomayo wrote:I figured the JTM45 could fit the bill. But how's the
clean tone?
The one I built uses iron recycled from an Arkay FL-30 that ran a pair of EL34's. It is a loud amp and there is quite a bit of decent clean tone on the amp. I think, as long as you get a decent OT for it, you will be able to milk it for all the clean you want. If you need a bit of grind at lower volume, a pedal will get you there in a hurry. When you crank it up, it will give you that Brit-flavoured dirt that Marshall is famous for. IMO, if you can manage the loud part, this is a great amp.
jaysg
Post by jaysg »
Based on my experience with that Allen OT and a similar EMC OT, the basic 5F6-A/JTM45 design fitted with EL-34's or KT-77's will probably fit the bill. Bassman cleans aren't bad at all. Alternately, a well built Super Reverb is a heavy hitter when dimmed, so the ab763 does well too, and then you've got the pretty BF cleans.
Lonely Raven
Post by Lonely Raven »
AB763 is a huge hurdle for a beginner amp builder.
Jack of all Trades,
Master of None
jaysg
Post by jaysg »
Lonely Raven wrote:AB763 is a huge hurdle for a beginner amp builder.
Not if you build it single channel without reverb or trem. It's pretty compact that way.
fabiomayo
Post by fabiomayo »
Thanks for the tips guys.
I liked both ideas JTM45 or Super Reverb (though I won't be adding
reverb or tremolo). I guess it's up to my friend to decide.
Maybe I could build a Bassman/JTM power amp with one JTM45 preamp
channel and one blackface. Make it footswitchable, maybe put a pre-PI
master volume on the marshall side.
What do you guys think?
jaysg
Post by jaysg »
I don't think you get much from a pre-PI master with either BF or Bassman preamps. A JCM800 2203/4 preamp variation is more or less the starting point for a master volume marshall. VVR/Power scaling would make the amp more useful.
dave g
Post by dave g »
Why don't you try a JTM45 with KT66s and a fender/marshall hybrid tonestack (try a stock blackface fender tonestack with .022s for both the bass and mid caps and change the mid pot to a 25k)? Go the extra mile and add VVR and I think you'd have something special :wink:
