Preamp Cathode Bias Resistor value in 5F1
Gregg Hermetech
Post by Gregg Hermetech »
Quick question: My 5F1 clone has 1.5k cathode bias resistors on V1A and V1B, for a 12AX7 (gain factor of 100). I've replaced it with a 12AY7 (gain factor of 45) and much prefer the tone, reduced gain, more clean headroom etc. Is the bias resistor still within an "acceptable range" for a 12AY7, or is it now too hot, or too cold? Is there a way to work out what I should replace it with, if needed? I'd like maximum longevity for the preamp tube, i.e. a safe bias setting at idle (I keep the amp on all day most days, even when not playing through it, and am using an expensive NOS tube).
I'm a relative newbie so please go easy/explain clearly. :D Thank you very much in advance!
https://musicwall.app/hermetech
Gregg Hermetech
Re: Preamp Cathode Bias Resistor value in 5F1
Schematic if helpful:
ampdan
Post by ampdan »
It's fine.
I don't know what plate voltage you have on the preamp power supply node, but if it's typical of 5F1 you are far from the plate dissipation limit on either tube type.
Gregg Hermetech
Thanks! Yes, pretty typical 5F1 (changed a few components to reduce flub/add treble), so good to know all is within spec.
B Ingram
Post by B Ingram »
Gregg Hermetech wrote: Fri Sep 05, 2025 11:51 am Quick question: My 5F1 clone has 1.5k cathode bias resistors on V1A and V1B, for a 12AX7 (gain factor of 100). I've replaced it with a 12AY7 (gain factor of 45) and much prefer the tone, reduced gain, more clean headroom etc. Is the bias resistor still within an "acceptable range" for a 12AY7, or is it now too hot, or too cold?
Fender used 1.5kΩ for 12AX7 and also for 12AY7.
That latter schematic shows "820Ω" but it also has 2 triodes sharing the resistor:
820Ω x 2 = 1640Ω, so
"Tube-Current x 2 x 820Ω" roughly equals "Tube Current x 1500Ω"
