How electricity really works videos
Post by Mark »
Okay, a disclaimer, I don’t really understand how electricity physically works but I thought these videos might be good for conversation.
If you can simply explain it all the better.
https://youtu.be/bHIhgxav9LY?si=1R3bTZs59H1FYSvj
https://youtu.be/oI_X2cMHNe0?si=hzQ9wYt37YfSE8fB
Yours Sincerely
Mark Abbott
Re: How electricity really works videos
Post by Stevem »
This and a copy of ohms law wheel will make for easy help .
Post by Mark »
Stevem wrote: Sat Feb 22, 2025 6:29 pm This and a copy of ohms law wheel will make for easy help .
Thanks for your reply, but my question is more about the actual electron flow. The guy in the clip uses the analogy that the electron are moving to and fro at a given frequency and why is charge going in one direction when the electrons are moving in two directions. His question was, shouldn’t energy be removed in the opposite direction of electrons.
He also mentions the Poynting vector which measures how much electromagnetic energy is passing through an area per second.
Yours Sincerely
Mark Abbott
Post by Mark »
Yours Sincerely
Mark Abbott
TUBEDUDE
Post by TUBEDUDE »
Not a bad simplification, but voltage should be pulling electron thru the resistance instead of pushing,
as voltage attracts electrons from ground through resistance.
patrick620
Post by patrick620 »
Damn I am old https://www.google.com/search?sca_esv=a ... PrNe8,st:0 I did notice one bit of misinformation in the skit.
Post by Stevem »
There’s no polarity shown, but current flows from negative to positive and this derails some folks at first, especially with tube based electronics.
