I have a Mojotone 18 watt TMB build with an issue I'm trying to track down. I'd like to wire in a preamp out and a power amp in so I can determine where the issue is in the amp. Essentially I want to temporarily wire in a temporary loop. That way I can run the preamp into the loop of my Fryette to test that, then run the Fryette preamp into the power amp to test that.
This is how I'm thinking of wiring it in (in green). Would this work? There are also the other modifications I've done to the schematic shown in color.
Passive loop to help with debugging
Re: Passive loop to help with debugging
Looks good.
What is the issue you are trying to narrow down?
And yes that mod will work fine.
