AN Wonderland Contour Circuit
W5FH
Post by W5FH »
Hello-
I am in process now of building a copy of the John Mayer Custom Reverb/ AN "Wonderland" amplifier based on info gleaned on this site. Attached is the schematic. My question revolves around the "contour" control, namely C-29 (4n7) and R-51 (250KA pot) of which are across the output of phase inverter. I have not incorporated this circuit into a build yet and was curious about its operation and how important it is to the character of this amplifier. The front panel is fairly crowded and I will have room for either the "contour" control or a "presence" control but not both. I like the Hiwatt phase inverter and its presence circuit and was thinking of incorporating it into this build. I have tried to research this circuit both cannot find anything about it so if anyone here has a few moments to educate me on what the "contour" control is doing I would appreciate it. As I understand the pot and 4n7 capacitor is a controlling the frequencies that apparently are being cancelled, as the phase inverter triodes are 180 degrees out of phase? Is this control important to the operation of the amp? Have watched some videos and observed some use of the control.
Also I am going to use a 6K6 reverb driver with an Edcor 7K to 8 ohm driver transformer, in a circuit similar to old Fender 6G15 Reverb unit. Keeping 6K6 plate voltage around 250 vdc or so to not drive pan too hard.
sluckey
Re: AN Wonderland Contour Circuit
Post by sluckey »
W5FH wrote: Sun Oct 06, 2024 11:05 pm My question revolves around the "contour" control, namely C-29 (4n7) and R-51 (250KA pot) of which are across the output of phase inverter.
It's exactly the same as the Vox top cut. Look here...
https://sluckeyamps.com/VAC15/Vox_AC15.pdf
Roe
Post by Roe »
the vox top cut is simpler than the SSS high filter but very effective for removing top end. I prefer a no-load pot myself since the stock vox circuit reduces gain and brightness slightly even when you turn down the cut control
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
W5FH
Post by W5FH »
Thanks for replies-
I found lots of info under "Vox Top Cut" searches, thanks for tip there. I wanted to ask Roe what he means by a "no load pot"?
Thank you.
timrobertson100
Post by timrobertson100 »
I find the contour in my wonderland very useful and would recommend keeping it.
sluckey
Post by sluckey »
W5FH wrote: Tue Oct 08, 2024 4:07 am I wanted to ask Roe what he means by a "no load pot"?
A no load pot becomes an open circuit when turned all the way in one direction. This has the same effect as connecting a switch in series with the pot. It totally removes the top cut circuit.
https://www.tubesandmore.com/products/p ... ft-no-load
W5FH
Post by W5FH »
Thanks all for helpful replies.
