Hello,
Curious to see if anyone went this route in alternatives to Fender pilot lamps.
While layout this stereo plexi I'm building, I see I'll want to use the full 11.8" turret board length. That however will get in the way of using those nice BIG/LONG Fender jewel lamp fixtures. I really like them but, they are just to big for this layout.
Has anyone used those 6V LED lamps such as I found on the LEDlights.io website.
I imagine those work fine with the 6.3vac heater supply. You can pick a variety of voltages that match to different color of choice, which I thought was kind of nice.
Thanks, hate to not use those pretty Fender jewel lamps but, provisions have to be made sometimes.
Best,
Phil D.
LED pilot lamps for front panel amp power
Re: LED pilot lamps for front panel amp power
I have been using these for a few years. https://www.mouser.com/ProductDetail/593-CMC441RTP comes in a few colors.
5mm led plus another diode in antiparallel and ~1k series resistor for 6.3vac. One layer of heatshrink to cover all of that gives a nice friction fit. I usually add a dot of nail polish as a thread lock.
You could also attach the fender jewel another way, ignore the large mounting stuff, then put a led behind. Unfortunately, I don't believe there are nuts commercially available for the weird threading of the fender jewel, but you can buy a tap and make your own if you are inclined.
I drill a hole in the panel and epoxy a 5mm LED with the surface ground roughly flat with 220 grit to diffuse the light and flush mount.
I have used a lot of these LED bezels from eBay. Easy to use and look good. Drill a hole. Install the bezel using a nut. LED slips in from the back of the bezel.
Since everyone else is sharing pictures, here's one with the plastic lens I mentioned.
Here's some 3M reflective tape as a lens.
Thank you all for helping to generate idea for other Lamp power indicators.
I did finally find one at Mouser - a 120vac neon 10mm diffuse red half bullet looking thing. It draws 1.9mA and needs a .5 inch hole. Its 0.9" long which will fit in the available space.
It wasn't easy finding a 6.3vac lamp but, it doesn't need to be that. Its just as easy to hook up a 120vac lamp.
Thank you all again!
Best,
Phil D,
Best,
Phil D,
