EL 84 circuit
EL 84 circuit
A while back I salvaged a power transformer and output transformer from an old radio console. I posted to here to ask for help identifying the transformers and had a few responses that indicated the transformers were likely from Ceco Manufacturing. The console looked like it was probably from the 1950's had a 5y3 rectifier, two el84 power tubes and three Mullard 12ax7s. The transformers are in good shape and I want to make an amp using these components and ask for advise for circuits to consider. I found a schematic for a Blues Jr. which use these same components and that is an option. I had a Blues Jr. and was less than impressed with the circuit and eventually sold the amp. I have built a number of amps and want to make this from parts that I have on hand. Would appreciate any other circuits to consider that are in the 10 to 15 watt range for output.
sluckey
Re: EL 84 circuit
The Dual Lite is my all time favorite 15 watt build. Your components are a perfect fit but you would have to trade one of your 12AX7s for an EF86. You would not be disappointed.
https://sluckeyamps.com/dual_lite/dual_lite.htm
Re: EL 84 circuit
The Blues jr suffers greatly from a small cabinet and a small speaker, so with whatever amp you do build go with a cabinet the size of a Deluxe reverb and a 12” speaker.
Re: EL 84 circuit
Steve,
Was this amp your favorite tonally and fit your playing style and preferences, or because it was a fun build, or both?
Re: EL 84 circuit
It is a very lucky find on the transformer set! I wouldn't feel obligated to that exact tube compliment and there's no harm going down to 2 12AX7's (or something like that) or using a pair of other power tubes like 6V6 (lower plate current requirement.) You can, however, be assured it will work with 3 preamp tubes and a pair of EL84. There are many amps that will fill out this tube compliment nicely. In the Marshall family, I like either flavor of the 18W -- the one with tremolo, or the 18W TMB. You might look at Vox. Other suggestions already made are sure to be winners. I don't think I'd build a Blues Jr. given the other options.
Re: EL 84 circuit
Both. I like the simplicity and I like the sound. Both channels sound great through my 2x12 Celestion cab. The Vox preamp really sparkles through my 1x12 Celestion Blue.
Re: EL 84 circuit
Thanks Steve. I've enjoyed the 18W EL84 amps over the years. I've tried loads of variants but usually come back to the Lite IIb format.sluckey wrote: ↑Sun Jun 16, 2024 5:16 pmBoth. I like the simplicity and I like the sound. Both channels sound great through my 2x12 Celestion cab. The Vox preamp really sparkles through my 1x12 Celestion Blue.
Re: EL 84 circuit
Yeah, the Lite IIB is just a solid Marshall sound. I like it better than my Plexi style amps.
Re: EL 84 circuit
Excellent suggestion. Beautiful build into a hand built combo style vox cab. I have a dual el84 Chassis and might have a go at this. The celestion blue is pricey but I can hear the chime just looking at the pictures. Very nice.sluckey wrote: ↑Sun Jun 16, 2024 3:30 am The Dual Lite is my all time favorite 15 watt build. Your components are a perfect fit but you would have to trade one of your 12AX7s for an EF86. You would not be disappointed.
Re: EL 84 circuit
Too bad 6973’s are so hard to come by and expensive, there a great tube for hard hitting build.
Re: EL 84 circuit
Interesting I have 2 amps out of an organ that use 6973’s. It’s currently used to drive a single 10” Leslie that came came out of the same organ. I’ve been hanging on for some future amp design.
Re: EL 84 circuit
I built a Supro S-6424 several years ago. I really liked it. I later sold it and the buyer wanted me to convert the 6973s to EL84s. Still sounded good. Now I have a pair of slightly used 6973s with no home.
Re: EL 84 circuit
Thanks for the recommendations. I have previously built a 18w tmb and really like both sides of the amp. I am also intrigued to have an AC15 side of the Dual Lite that Sluckey recommended. I looked at the schematic and layout and it looks to be in my wheelhouse. The layout includes a PPIMV which I have on a 5e3 that I also really like. One question I have is if the Dual Lite would lend itself to having a negative feedback circuit. I installed a negative feedback circuit on my 5e3 following Rob Robinette's schematic and it is a really interesting feature to add. If so my advice on how it would be configured
Re: EL 84 circuit
This is how I would add NFB to the Dual Lite. May lose some of the simple charm.
Re: EL 84 circuit
@Sluckey, any recommendations on Hammond transformers that could be used for the Dual Lite ? Would a 272X be enough for a PT ? How about for the OT ?
