AND, after removing the resistor, do I just leave it open, or do I need to re-complete the path, w/o the resistor?
Kindly point out on schematic...
Thnx, Kenny ॐ
If you clip it, you might not be able to reconnect the resistor. I would desolder one end of the resistor and gently lift/bend the lead out of the way. Then I would test the amp with no NFB and hear how it behaves.
