18 watt bias drop
plook
18 watt bias drop
Post by plook »
Hi, I made an 18 watt TMB with MV about 10 years ago and gave it to a friend. The voltage measured at cathode resistor 120R and pins 3 of EL84 is 6.24v and should be 10v. What could have caused it to drop and how to fix. My amp work is very intermittent now, big gaps before I come back so my knowledge base is not what it was on diagnostics.
sluckey
Re: 18 watt bias drop
Post by sluckey »
Weak tubes would be my number one suspect.
plook
Post by plook »
sluckey wrote: Sat Jan 14, 2023 12:52 pm Weak tubes would be my number one suspect.
That’s what I thought. I put a brand new set in and around the same reading of 6v.
sluckey
Post by sluckey »
Measure voltage on pins 2, 7, and 9 for both EL84s. Looking for six numbers here.
plook
Post by plook »
sluckey wrote: Sat Jan 14, 2023 1:37 pm Measure voltage on pins 2, 7, and 9 for both EL84s. Looking for six numbers here.
V4 EL84
p2 fluctuates 0.1 to 0.8 MV
P7 424v
P9 420v
V5 EL84
P2 fluctuates 0.1 to 0.5 MV
P7 424v
P9 420v
wpaulvogel
Post by wpaulvogel »
Plate and screen voltage are high along with the low cathode voltage. I’d check the ground connection of the cathode unless you were checking the cathode voltage at a different chassis reference point than the ground lug for the cathodes.
plook
Post by plook »
wpaulvogel wrote: Sat Jan 14, 2023 2:53 pm Plate and screen voltage are high along with the low cathode voltage. I’d check the ground connection of the cathode unless you were checking the cathode voltage at a different chassis reference point than the ground lug for the cathodes.
Have had a good look, pressed down on the ground with a chopstick. Latest readings:
V4
P2 59mv
P7 329v
P9 321v
V5
P2 4.0mv
P7 334v
P9 323v
It’s a mystery
sluckey
Post by sluckey »
So, with the latest voltage readings did the cathode voltage go up to about 10V?
plook
Post by plook »
No, that is 6v on both pin 3s
plook
Post by plook »
plook wrote: Sat Jan 14, 2023 5:50 pm No, that is 6v on both pin 3s. Tried different sets of tubes too.
sluckey
Post by sluckey »
That's crazy. Your plate voltage dropped about 100V which indicates a big increase in plate current. That same current must flow through the cathode resistor, yet you say the cathode voltage is still 6V. Very odd. Maybe your meter is lying to you.
plook
Post by plook »
sluckey wrote: Sat Jan 14, 2023 6:29 pm That's crazy. Your plate voltage dropped about 100V which indicates a big increase in plate current. That same current must flow through the cathode resistor, yet you say the cathode voltage is still 6V. Very odd. Maybe your meter is lying to you.
That’s a good point. I’ll put a new battery in the metre and re-test.
plook
Post by plook »
plook wrote: Sat Jan 14, 2023 6:33 pm
Fresh battery and p3 still 6v.
sluckey
Post by sluckey »
About the only thing left to do (and should have suggested this sooner) is measure resistance from pin 3 to chassis. If less than 120Ω replace the cathode capacitor.
plook
Post by plook »
sluckey wrote: Sat Jan 14, 2023 8:52 pm About the only thing left to do (and should have suggested this sooner) is measure resistance from pin 3 to chassis. If less than 120Ω replace the cathode capacitor.
Thank you. I’ll try that in the morning. Appreciate it.
