Squawk box speaker issues
angelodp
Post by angelodp »
Hi, have this little soldi state squawk box for bench stuff and more. The internal speaker has a bit a low level gravelly noise.... very low. The extension speaker out to an 8ohm cab is crystal clear.
Any ideas on trouble shooting this. Power caps seem fine and components are in good shape, cleaned all pots and tightened all pots.
Re: Squawk box speaker issues
Sounds like the speaker coil is rubbing. Bad speaker!
angelodp
Post by angelodp »
ah, ok I'll source a small 8 ohm to replace.
thanks A
angelodp
Post by angelodp »
Having a heck of a time finding the replacement speaker. 8 ohm 5 watt 5.25"
Any suggestions for sources?
A
pompeiisneaks
Site Admin
Post by pompeiisneaks »
This is a little overkill at 20W but 8 ohm and 5.25"
https://www.digikey.com/en/products/det ... mbEALw_wcB
~Phil
tUber Nerd!
bmx
Post by bmx »
Here is another with resonant frequency at 100Hz, but without quite as extended of a top end:
https://www.parts-express.com/GRS-5PF-8 ... er-292-405
I was going to recommend parts-express.com also.
angelodp
Post by angelodp »
