is there any particular reason why an amp should have a scratchy volume pot right after power up, like as soon as standby is off (amp fully operational)  the volume pot is scratchy for about 1/10th of it's taper and only happens for a few seconds.
Also it's very noticeable if humbucker guitars are being used. after this small period the scratchyness disappears.
any ideas, can't read any DC across the pot.
						Scratchy pot at power up??
- Funkalicousgroove
Re: Scratchy pot at power up??
try cleaning it and get back to us, if that doesn't fix it could be something else.
I haven't removed the pot for cleaning yet,but it occured to me it can't be dirt, since it only does this right after power up, than the noise is gone.
Sounds to me like you may have a leaky cap leaking dc onto the pot untill the amp voltages stabilizes. Maybe try changing the coupling cap going to the pot. Just a thought
And also try using a different preamp tube.or a funky ground connection. But it does sound like a leaky coupling cap.
+1 Had the exact same fault with a Marshall last month,try the
coupling caps
cheers
paddy
