First build crackle n pop.. benson monarch.
unknowntome
Post by unknowntome »
Hello! I posted this query over at the benson monarch thread however I think its best suited here.
So, Id been following that thread since it pretty much started and, with much preparation, built my first amp! Thank you to everyone who contributed to that thread... incredible! I used BobL's layout with the only difference being the HV centre Tap going to ground as most have done. Overall, hum and noise is 'acceptable' and on par with my Bluesbreaker. I have two issues with the build though...
first: there's persistent pop and crackle. it shifts and is dynamic but there.. doesn't go away... chop sticking doesn't make any difference. Ive read lots of different posts/threads whereby a couple of key changes from CC to CF resistors can make all the difference.. hoping to get some ideas re this… ?
Second: the reverb sounds great up until the last 20% of the sweep where the signal is killed and replaced by a hum.
I used the 290BEX PT and the 1750H OT.. both hammond. Im in Australia so 240v mains.
I used CC resistors throughout the build.
My voltages are about 20% higher than the schematic.
I also, as I do, made it more complicated by building it using a completely different layout! More aligned with hifi tube amplifiers.. see pics... but its pretty much worked out except for the two issues above so am feeling pretty good about that for a first build! It sounds fantastic! There could be a little less hum… but as it is I can live with that.
any ideas re above?
Layout (I added the power section… incl artificial centre tap resistors)
https://i.imgur.com/qdmtx3U.jpg
Build images
https://i.imgur.com/USMBisq.jpg
https://i.imgur.com/n2wylFc.jpg
https://i.imgur.com/jEIjrSM.jpg
https://i.imgur.com/keNybKx.jpg
https://i.imgur.com/DcizkGL.jpg
Cheers!
brewdude
Re: First build crackle n pop.. benson monarch.
Post by brewdude »
Bad solder joint?
Did you check PA bias and plate dissipation?
unknowntome
brewdude wrote: Tue Jun 21, 2022 3:40 am Bad solder joint?
Hey! I haven’t done a thorough check re solder joints.. I was planning on resoldering all accessible joints to begin with… tube sockets mainly. On close inspection the lugs on the turret board don’t have solder all the way around them but am certain that there’s good mechanical connection with ample solder on at least the side where the heat was applied from where the solder flowed.
Not sure what you mean exactly by checking PA bias and plate dissipation… this is my first build. :) .. keen to know though!
Post by Stevem »
Your output tube cathode bypass cap needs to be moved off of the body of that 5 watt resistor.
Heat is going to eat that cap up real fast other wise!
unknowntome
Stevem wrote: Tue Jun 21, 2022 10:32 am Your outout tube cathode bypass cap needs to be moved off of the body of that 5 watt resistor.
Hey.. yeah there’s space between the two although it doesn’t quite look like it in the pic.
Post by Stevem »
Well first yank out your preamp tube and if it stops ( assuming its not the tube ) then you have narrowed it down to those two gain stages, or the power supply node that is feeding them.
Most pops & crap are from plate load resistors and near twice a week here at work with brand new products I deal with bad noisy plate load resistors, so don't assume because they are new that there good!
unknowntome
Stevem wrote: Tue Jun 21, 2022 3:48 pm Well first yank out your preamp tube and if it stops ( assuming its not the tube ) then you have narrowed it down to those two gain stages, or the power supply node that is feeding them.
Thanks.. I’ve got a couple of questions.
- can I pull out the tubes with the amp on? Or do I completely power down, remove, and then power up?
- should I methodically start with V1 moving through to V3?
Post by Stevem »
Yes you can remove any of the preamp tubes with the amp on but you will get popping and noises out thru the speaker, but no harm will come to the amp.
Turn the amp off or into standby to put them back in.
Start one at a time with V3 and if no change is heard pop that back in and move on to V2 and so on.
unknowntome
Great, thanks for that.. I’ll give that a go this evening.. is it a good idea to pull them out whilst in stand by mode then turn it on? Then turn off to reinstall?
brewdude
Post by brewdude »
They might be HOT
unknowntome
brewdude wrote: Wed Jun 22, 2022 12:38 am They might be HOT
Haha.. yeah I know.. will have gloves ready to go if I need them
unknowntome
Stevem wrote: Tue Jun 21, 2022 10:39 pm Yes you can remove any of the preamp tubes with the amp on but you will get popping and noises out thru the speaker, but no harm will come to the amp.
So I just ran the experiment.
Pulled out V3 - crackle persisted. Reinstalled.
Pulled out V2 - crackle stopped. Reinstalled.
Pulled out V1 - crackle stopped. Reinstalled.
Hmmmm…. What next?? :)
pdf64
Post by pdf64 »
Link for schematic?
The layout image seems rather blurry, and different to the photos?
Regarding the second issue, have you scoped it for oscillation?
Post by Stevem »
What you reported back with is impossible if V3 is the tube that is driving the output tubes!
unknowntome
Stevem wrote: Wed Jun 22, 2022 10:40 am What you reported back with is impossible if V3 is the tube that is driving the output tubes!
I’m pretty certain V3 is the reverb tube.. V2 is connected to the output tube.. V1 to input…. Based on the layout I’m working from and linked in my initial post.
