Tube preamp pedal output impedance
the_jessmo7
Post by the_jessmo7 »
Hello all,
I’m wanting to build a Two Rock style tube preamp pedal. What is the best way to ensure a low output impedance? What’s the easiest way? Open to all suggestions.
Re: Tube preamp pedal output impedance
Post by Stevem »
If you want low output impeadance then the output jack should be driven by a Cathode follower circuit.
These type stages have a hair less then unity gain so the gain stage before the follower will need to provide the signal level your looking to have available.
mhuss
Post by mhuss »
Depending how "pure" you want to be, you could also use a MOSFET source follower on the output, so you could save the triode for gain instead.
Andy Le Blanc
Post by Andy Le Blanc »
matching transformer
lazymaryamps
chaccmgr
Post by chaccmgr »
in case you opt for a Mosfet, the LND150 can withstand tube-like voltage (up to 500V) and can be a direct replacement without changing a normal cathode follower topology (of course not in a tube socket) and it's dead cheap (pennies). It is widely used for this purpose.
